diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Look for EL33 PP structure circuit (http://www.diyaudio.com/forums/tubes-valves/55331-look-el33-pp-structure-circuit.html)
RCA245 13th April 2005 09:50 AM
Can everybody help to offer? ;)
planet10 13th April 2005 07:31 PM
one of my favorites from Vaccuum State Electronics
http://www.vacuumstate.com/schematics/pp-1c_s.gif
dave
and the power supply
http://www.vacuumstate.com/schematics/pp-1c_ps_s.gif
leadbelly 13th April 2005 07:35 PM
dave
No, that's not a typo, he really means EL33:
http://www.diyaudio.com/forums/showt...threadid=55148
planet10 13th April 2005 07:40 PM
Oops... not a tube i've heard of before... same circuit would work, but with adjustment of cathode R & an OPT with a lot more pimary -- looks much more like an EL84 then an EL34.... i'm using the above as a basis for a PP amp with EL84s leveraged off a pair of Dynaco SCA35s
http://www.mif.pg.gda.pl/homepages/f...001/e/EL33.gif
dave
planet10 13th April 2005 07:41 PM
To continue... go looking for circuits for EL84/6BQ5, 6AQ5, 6V6, EL95, ELL80, adjust the cathode circuit and power supply as necessary....
dave
RCA245 13th April 2005 09:30 PM
http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
Thank you very much for the help of dave and leadbelly. :D
http://artifactaudio.com/EL33specs.JPG
Ask dave again. Please tell me?
In the webpage "Two valves in Push-Pull".
Va=250V
Vg2=250V
Rk=140 ohm
Vin=13V
I can change the circuit of this 6V6 below its Va , Vg2, Rk and Vin, make it become circuit of EL33 PP?
Make having 296V in the picture into 250V,
Rk =250 ohm is changed into 140 ohm,
Make with 18V into 13V.
Can become EL33 PP in this way?
Thanks.:D
planet10 13th April 2005 09:41 PM
Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
http://www2u.biglobe.ne.jp/~tossie/6V6PP.sch.gif
pretty much... i'd put a CCS on the cathodes of the long tail pair and just use it as the phase splitter and gain stage (you might need a higher gain tube) -- this would eliminate the 1st 2 stages.
dave
RCA245 14th April 2005 12:16 AM
Re: Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
dave [/B]
Dave, thanks your replying.
Sorry ! What is CCS? :dead:
If use this circuit below, OK?
http://www.tubecity.com.tw/images/cir3.gif
Or change the 1st 2 stages (first 6sn7) into EF86 etc . high gain tube?
But change into high gain tube, so become bad linearly?
Thanks.
planet10 14th April 2005 02:05 AM
Re: Re: Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
2 Attachment(s)
Constant Current Source
That is the same circuit, different ouput tubes and details ...
EF86 straffed in triode is excellent.
something like this is what i suggest (note similarities to PP1C above)
dave
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
