Valve Identification-Help - diyAudio
Old 11th April 2005, 08:20 PM   #1
Default Valve Identification-Help
I have just opened my Audio Research SP9 Mk11(a recent purchase) to check the type of valve installed. They are marked E88CC in white lettering about one quarter the way up the valve and have SQ in large white lettering above that. There appear to be no other identifying marks on the valve and base. Do I have a desirable Philips SQ valve, a lesser valve or a counterfeit. Grateful for some advice before I spend money on replacements!
Old 11th April 2005, 08:47 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
I know very little about valves but here's an attempt to answer part of your question.
E88CC is the high grade ECC88 which is a double triode.
I was told by an older technicians who grew up with valves.
(No flame war of elders amongst us please)
/Hugo
Old 11th April 2005, 11:14 PM   #3
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
E88CC = ECC88, but fancy.
longer life or better shock handling or something along the lines of that.
Old 11th April 2005, 11:18 PM   #4
forgot the datasheet.. here's one that says all the special features. for use at home, the difference is not a hell of a lot, really.
might matter in a bomber or a missle.. but not on your coffee table. http://frank.pocnet.net/sheets/128/e/E88CC.pdf
Old 12th April 2005, 12:32 AM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
A real NOS E88CC tends to be less microphonic than a real NOS ECC88. Can't comment on recent production.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 12th April 2005, 11:51 AM   #6
Banned
Its a Special Quality ECC88 (6DJ8 and 6922) and i have been told that ECC88, E88CC, 6DJ8 is a bad tube for audio.
Old 12th April 2005, 12:04 PM   #7
EC8010's Avatar
You'd better let Audio Research know because they use them by the truck load!
The ECC88 family is very useful for audio.
Old 12th April 2005, 12:41 PM   #8
SY's Avatar
Well, that's it. Toss those Marantz 9 amps in the dumpster.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th April 2005, 01:46 PM   #9
tuben is offline tuben  Sweden
Tekko said
"Its a Special Quality ECC88 (6DJ8 and 6922) and i have been told that ECC88, E88CC, 6DJ8 is a bad tube for audio."
Comments like this should be followed with some arguments that support the opinion..........or not be spoken at all.
Tuben
Old 12th April 2005, 02:03 PM   #10
SY's Avatar
No, it's more a matter of Audio Urban Legend rather than anything that can be supported factually. And I even know how it started- many years ago, one of the "audiophile" tube suppliers sold a pile of 6ES8 (a variable mu triode) labelled as 6DJB/ECC88. These tubes were, unsurprisingly, quite nonlinear. There was even an article in Glass Audio about how horrible 6DJ8 triodes were. So despite the fact that there was one batch of nonlinear tubes sold by an uscrupulous merchant which weren't even 6DJ8s, and thousands of batches of perfectly fine 6DJ8s sold over the decades and used in classic equipment, the legend stuck. And no number of counter-examples will kill that legend.
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 01:15 PM
Help with Cap identification SVinzant Parts 3 22nd January 2009 01:54 PM
Need identification if possible. es44 Full Range 2 11th September 2008 09:38 AM
Copyright 1999-2017 diyAudio
