Old 11th April 2005, 12:20 PM   #1
Default KT 88 schematic search
Hi to all. Iwas just wondering if any of you knew any good sites in which I can find schematics based on kt88's, be it PP or single ended. I am looking at building a new project and would like to build a power amp that will suit my Tannoy R2's. Not at the loud level, but at the clear level is prefered.
Thanks heaps
andrewe1
Old 11th April 2005, 02:06 PM   #2
protos is offline protos  Greece
protos's Avatar
Look at the Plitron site.
Old 12th April 2005, 07:12 PM   #3
and http://www.ptsoundlab.com/sectubes/s...indexschem.htm
Old 13th April 2005, 01:53 PM   #4
Default Thanks
Thanks to you that have written in and answered my questions.
Old 14th April 2005, 04:18 AM   #5
Andrew,
I looked up Tannoy R2
Nominally 4 Ohm and 90 dB/W/m sensitivity.
Single Ended KT88 will NOT cut the mustard - not enuf wik.
You should be looking for Zout of <= 0.8 Ohms and Power >= 25 Watts.
Don't be tempted into parallel push pull KT88s (4 tubes) - you don't need that much power and its about four times as complicated a a single pair of KT88s in Push Pull.
If you are in Melbourne give Scott Thompson a call at Rarefaction or look up his web site.
If he has stock he may be able to lend you a Chinese built TAD800 (Aus$1795) which is an integrated stereo KT88 Amp or a TAD500 which is very similar but with EL34 (Aus$1495). I recall him saying that he preferred the EL34 amp over the KT88 amp in A/B listening tests.
You will be very hard pressed to build an amp for these prices.
I've got one of the 20W per channel 845 SET Amps. The build quality and parts quality are fairly good and with a few minor mods and some front end tube substitutions this has turned into a very nice amp. Like all SETs a bit much 2nd harmonic distortion when cranked for my taste. I have seriously considered buying one of EL34 or KT88 Amps myself but am persevering with a 4 x KT88 with Plitron Transformers for now, having spent the money on the transformers I'm committed!!! Or should that be I should be committed for spending the money on the transformers?
Ian
Old 14th April 2005, 10:44 AM   #6
Default Thanks Ian
Hi Ian and thanks for your help with my search in getting great amp. I will be building a power amp as I already have avalve pre that i am very pleased with.
Thanks again
andrewe1
Old 14th April 2005, 07:33 PM   #7
Banned
Default 90dB and power needed
Nominally 4 Ohm and 90 dB/W/m sensitivity. Single Ended KT88 will NOT cut the mustard - not enuf wik. You should be looking for Zout of <= 0.8 Ohms and Power >= 25 Watts.
Point is, I am currently mostly listening to my Heybrook Sextet speakers (less than 90dB/W/m) to my latest RH amp with KT88s (soon to be changed to 8417). The estimated power of the amp is in the 15W league, but even 10-12W WOULD CUT THE MUSTARD very nice, thank you very much.
Unless of course you need disco-club listening levels for parties attended by lots of friends (lots of dumping) in your 100m square living room...
Even some standard SE 300B amp with 8-9W of power would do! Don't be mislead by common "armchair knowledgeability" ideas.
Alex
Search for the Sugden A21 schematic danka Solid State 6 20th August 2012 06:47 PM
Search 35T Schematic olaychang Tubes / Valves 0 7th November 2008 10:50 AM
schematic search crate bv-60 vlljpior Tubes / Valves 0 26th October 2006 01:57 PM
35watts el34 amp schematic search ? vlljpior Tubes / Valves 3 9th April 2005 09:17 PM
in search of a schematic vlljpior Tubes / Valves 0 28th February 2005 11:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
