Old 10th April 2005, 08:10 AM   #1
Default project suggestion with spare trans
I have extra set of power trans and SE output trans from my darling project.
The output trans is rated 5watts and the pt output is 200v. The trans are custom-made, wax-potted and has very good freq response up to 50k.
I am considering a 2A3 project with these, or maybe exotic tubes. Any suggestions?
p/s- Initially I wanted to build a 300B with these, but I am guessing the rated power is not enough to be used.
Old 10th April 2005, 08:19 AM   #2
audiousername's Avatar
Something more exotic of course
What about SE trioded 829B?
http://www.pmillett.com/829b_amplifier.htm
Jason
Old 12th April 2005, 05:17 AM   #3
I think I will stick with the fashion... penthode driving 2a3 triode.
Not brave enough for exotics.
Old 12th April 2005, 04:01 PM   #4
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
6W6 or two.
12BY7 if you have a bunch (4 or so).
12B4.
I'd say 6V6 but it likes 250-350V.
'Bout 5 6SN7's
6BM8? Kinda low powered though.
New sweep tubes: GV5, GY5, JF6, ... would look neato; needs 12 pin socket though.
Tim
Seven Transistor Labs
Projects and Resources
Old 13th April 2005, 01:18 AM   #5
how about c45? good rapport i get..
12b4, 5687 too low gain, unfortunately.
I already have 6Bm8 amp..
6sn7.. good potential.
Old 13th April 2005, 07:26 AM   #6
Too low gain? One usually isn't too worried about the gain of the output stage as long as the drive requirements aren't too severe...
The µ of the 5687 (14, I think) certainly is high enough. Even the 12B4 (µ=6) is good enough.
Jason
Old 14th April 2005, 09:06 AM   #7
There are some nice low power triodes which are quite cheap. You don't state the Primary impedence of the OPT so you could chose between:
12B4 Ra 1
6CK4 Ra 1.2
6AH4 Ra 1.8
6S4A Ra 3.7
As you go up the Ra you may need to use pairs - certainly the case with 6S4A. As stated, multiple 6SN7 or 6J5GT are also ideas - I've heard those in outputs and they are very sweet and clear. 6J5GT are very cheap, and you can use 7N7 instead of 6SN7. 2C22/7193 would be fantastic, and they're not expensive. Of all the above, that would probably give you the best sound, but you'd need a few and some top caps.
Help for a beginner please : Spare time uni project! MCGroves Multi-Way 0 24th October 2006 02:27 AM
Suggestion for First DIY Project for Wife and I mlammert Multi-Way 13 15th September 2006 03:58 PM
Suggestion for my First Project gazolli Full Range 4 19th November 2005 09:07 PM
Advice or suggestion on first speaker project minh_827 Multi-Way 1 5th May 2005 06:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
