Why no CCS in PP output stage?
Old 8th April 2005, 07:10 AM   #11
reinhard is offline reinhard
Bill Beard is using one current source for each tube, bridged by a big capacitor, that is a completely other thing, more a bias regulation, nothing differential.
Reinhard
Old 8th April 2005, 07:16 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by SY
In the linked John Swenson schematic, the input stage is not a phase splitter, it's a plain vanilla single-ended voltage amp.
The V1 version of swenson's amp used a trafo phase splitter. Tony's "preamp" is already a differential stage with balanced output -- the idea was to use the output of that to directly drive the grids of the EL84s.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Why no CCS in PP output stage?Hide this!Advertise here!
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
Copyright ©1999-2017 diyAudio
