#11 |
diyAudio Moderator Emeritus
Hmmm. My experience is that you probably do need two stages of LC smoothing on the HT with a single-ended amplifier.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#12 |
Or active regulation. A nice MJ423 (darlingtoned with a small-signal HV npn) standing off an LM317 could do wonders for hum and noise.
(ducking and running)
If there's a sucker born every minute, where do the rest of them come from? |
#13 |
Or a nice MOSFET. Or even a valve regulator. Perhaps even shunt. Given a chance, your amplifier could be completely redesigned - with the bonus that none of the "designers" would take any responsibility for the outcome.
#14 |
Re-designers is exactly what I am looking for! As I come here because my knowledge ran out. Hopefully, many of my mistakes (I'm sure there is many) can be easily spotted by the more seasoned builders and designers.
With respect to regulation, I contemplated the possibility but I stayed clear of it in the interest of simplicity. I also looked at many designs for SET amplis and many of them came out without regulation. I do not discard the idea, but I will dive into it only if necessary. Rada |
#15 |
Fair enough. When you don't have much experience, it's better to keep things simple. Regulators can have all sorts of nasty problems that require considerable investigation with a decent oscilloscope. Consider a dual chassis design with power supply on one chassis and amplifiers on the other. Perhaps leave room for a regulator and choose power transformers that could accomodate a regulator at a later stage.
#16 | |
Why anyone uses valve regulators in this day and age can only be attributed to sheer cussedness. Or (in my case) laziness.
#17 |
I made a valve regulator recently and was pleasantly surprised by its stability and noise. Naturally, it needed dedicated heater supplies and attention to their noise. And it took up a bit of chassis space. And it dropped twice as many volts as silicon.
#18 | |
#19 |
I downloaded the LM317 datasheet and I am going to study it.
As for Morgan Jones, I got most of the basics from his book and I found it superb. I remember, however, that in the case of his only single ended example (The Scrapbox Challenge), he went for a solid state regulator because he did not have at hand the adequate components for an efficient LC filter. I will try to implement a solid state regulator based on his designs. Back to studying again! Cheers, Rada |
#20 |
Better yet, find Michael Maida's applications brief for using the 317 at high voltage. Note that MJ used the 317 as the regulator for the Crystal Palace amp.
| Please review my design | kilowattski | Analogue Source | 69 | 29th March 2011 05:54 PM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| Design review? | Sawzall | Digital Source | 0 | 6th July 2003 05:47 AM |
| Hi/Review Design | Sch3mat1c | Tubes / Valves | 37 | 29th January 2003 02:30 PM |
