| diyAudio Sponsor | ||
#31 |
Item location: Melbourne, Victoria
They've already invaded! http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW 2A3 tube x4 (2A3 tube is regarded as the best tube to produce human vocal sound) AU $450.00 Approximately US $347! Cheap as chips (but sound like chocolate) |
#32 | ||
I find it more useful to ignore certain types of talk (and not extreme talk - it's actually the most common sort) and pay close attention to other types (much more rare.) This is the antithesis of statistics. I'm arbitrarily throwing away data! Quote:
I questioned the comparison because one is not compelled to accept a compromise. It was correctly stated that a lower turns ratio has higher bandwidth, but it was not stated that you could get better than acceptable bandwidth using the higher turns ratio. If the lower turns ratio gets you to 100kHz vs 50kHz, do you get any benefit? |
#33 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#34 | |
| Safety Practices, General and Ultra-High Voltage | DrDeville | Tubes / Valves | 220 | 20th April 2012 11:20 PM |
| High DAC Output Voltage (2.7 Volts) | john65b | Digital Source | 4 | 29th December 2006 09:23 PM |
| Safety Practices, General and Ultra-High Voltage | DrDeville | Everything Else | 49 | 23rd September 2004 09:31 AM |
| Page generated in 0.07119 seconds (84.28% PHP - 15.72% MySQL) with 10 queries |
