Placement of power amp imput resistor
Old 30th March 2005, 01:45 AM   #1
trombone is offline trombone  United States
Default Placement of power amp imput resistor
What is best practice for placement of the input load resistor of a tube power amp? On the jack, or in the circuit closer to the tube grid?
Trombone
Old 30th March 2005, 09:17 AM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
It doesn't matter much. I would probably put it close to the valve, but Quad put it on the input socket of their Quad II power amplifier.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 30th March 2005, 09:34 AM   #3
Tekko is offline Tekko
Banned
I put mine directly on the input tubes socket.
Old 30th March 2005, 11:09 PM   #4
skyraider is offline skyraider  Malaysia
It does not matter from the grounding point of view.
I put it on the input socket to reduce the mess on the tube. Especially if you are using twin triode tubes, there is too many components there already.
Old 31st March 2005, 12:14 AM   #5
Dr. Photon is offline Dr. Photon  United States
I recommend placing it on the tube socket if at all possible. This will apply its low pass filtering (allong with the tube's miller capacitance) to remove radio frequencies on the amp input AND picked up anlong the wire to the tube. But it is not very critical, and many amps work just perfectly without this resistor. I sometimes try to have the tube socket physically close to what drives it (either volume pot or input jacks) and then use the input resistor as the connection between them to save wiring.
Old 31st March 2005, 01:15 AM   #6
anatech is offline anatech  Canada
anatech's Avatar
I've always seen it on the input jack. Especially on old equipment, and I really respect the older engineers who designed those. The tube sockets are busy enough already.
Guess where I install mine.
-Chris
Old 31st March 2005, 02:47 AM   #7
Sherman is offline Sherman  United States
How about putting the input jack close to the tube (on the opposite side from the heater wires) and soldering it to both?
--Sherman
Placement of power amp imput resistorHide this!Advertise here!
8" run in chassis before terminating SPDIF Signal... 75R Resistor Placement PaulHilgeman Parts 14 30th August 2008 02:16 AM
Series resistor placement angsuman Multi-Way 5 15th July 2006 12:06 AM
Bleeder Resistor Placement dsavitsk Tubes / Valves 2 31st December 2005 12:38 AM
GC input impedance resistor placement matjans Chip Amps 2 15th November 2003 08:06 PM
