| diyAudio Sponsor | ||
I just picked up a Stromberg-Carlson Model 20 PA amp for conversion into a guitar amp. It' sfrom the forties; two huge white chickenhead knobs on the front. Where do I start? WHo has schematics? Will human sacrifice be necessary to get it running? Thanks.
#2 |
Wow! Great! You could avoid remounting in a separate enclosure... that looks so cool!
The first thing in pa-guitar amp job is to check if the pa works as it was intended to work. First repair the pa then convert it to guitar amp. Sorry, no schematics. Could you tell us what tubes are inside? |
#3 |
pics PICS
Take some pics of the inside.
#4 |
My experience with Strombergs of this era is that the schematic is pasted on the inside of the bottom cover. Have you opened it up?
Michael |
#5 |
I think that the guy hasn't recived yet the amp in question... just look at the ebay logo under the picture...
#6 |
Poss Duncan amps..for schematics.....
Watch out......... .Sometime ago I across a golden oldie with AC/DC chassis of the sim vintage.....double check mains/line input.richj |
#7 |
I do indeed have the amp; I bought it on FleaBay and it was delivered yesterday, but posting the auction pic was quick and easy.
And it's pretty rough. A cap can is physically disintegrating, the wires out of the octal connectors have been cut, and it looks like it's been sitting for about thirty years. That's the bad news. The good news is that there don't seem to be any major corrosion issues, the cloth covering on the wires is intact and not fragile, and the solder connections look solid. And, it looks cooler than anything I've owned in my 47 years. More bad news: no schematic on the bottom cover, because there is no bottom cover. Lots of work before it comes within ten feet of live electricity, but I'm psyched. |
#8 |
So take some pics, i want to see this thing! Both inside and outside. What tubes does it use ?
#9 |
Photos will follow tomorrow; the tube lineup is 5U4, 6L6, 6L6, 6N7, 6J5, 6SJ7, 6SJ7.
#10 | |
YOU ARE A LUKY MAN! those tubes are very useful in a guitar amp... especially the 6L6 outputs... |
| FS: Stromberg Carlson AU-57 tube amp | whitelabrat | Swap Meet | 8 | 18th December 2010 05:26 AM |
| Stromberg-Carlson ASR-433 | Bran Kulez | Tubes / Valves | 10 | 20th October 2009 07:23 AM |
| Stromberg Carlson ASR 533 | kc5scs | Everything Else | 0 | 22nd January 2008 02:58 AM |
| Stromberg Carlson speaker...please help. | the_manta | Multi-Way | 5 | 7th March 2007 02:20 AM |
| Stromberg-Carlson 433 : Add standby or not? | Vespasian | Tubes / Valves | 6 | 17th December 2006 11:15 PM |
| Page generated in 0.10600 seconds (77.85% PHP - 22.15% MySQL) with 11 queries |
