Guitar overdriven preamp schematics? - diyAudio
Old 24th March 2005, 02:17 AM   #1
jsd is offline jsd  United States
Default Guitar overdriven preamp schematics?
I've been looking for some guitar preamp schematics with little success. I have 4 12AX7 tubes (3x Sylvania, 1x Wurlitzer) that I'd like to use. I'm looking for some good tube distortion, maybe similar to a Marshall. I'll be feeding a solid state amplifier from this, so of course it won't be the same.. but I want to get some of that crunchiness.
I've got a Fender Champ II which sounds good when overdriven, but I need a bit more.
I'm not looking for a lot of overall gain, I can always drop it back down after all the gain stages with a pair of resistors for a voltage divider.
Can I use two wallwarts back to back to get a high enough voltage? I don't know *anything* about designing tube amps (or solid state ones, for that matter).
Old 24th March 2005, 12:55 PM   #2
Default May be Matchless_hotbox?
http://www.metaleater.narod.ru/matchless_hotbox.pdf
Old 25th March 2005, 10:28 PM   #3
Trout is offline Trout  United States
Trout's Avatar
The McTubeII really overdrives very well, Has a very low parts count and is a fairly easy build. I built and own a couple !!
The McTube Site has a very comprehensive walk-thru on the build, And allows easy variations for modifications of original design. As near a perfect 1st project as I've ever seen.
I have another project that might be worth a shot but is as of yet untested, Basically it is roughly following the McTube mindset on its power source, This schematic goes a few steps further.
Roughly based on Seymour Duncan pre-amp modules*, Tone controls added & Drawn in indivual module stages for easy mods.
You can download it here classicpreamp
The originall idea was to build it for my brothers B-Day as an add-on to his solid state amp, I even went so far as to (ducking eggs and rotten tomatos) Make up the artwork for the printed circuit board.
Well, I set the project aside, And built him a 6AQ5A SE setup and just never got back to the project.
Hopefully I will find time to prototype it soon, then i can finalize & Debug the artwork and schematic.
NOTE, Not intended for beginners.
Gene
* note, there are about 9 interchangable modules with extremely effective tone and distortion/gain factors. Most of which are just value changes. Most can be modded on the same board.
Gene
Old 25th March 2005, 10:32 PM   #4
The last project looks interesting, what rating should the resistors be?
Old 25th March 2005, 10:51 PM   #5
Trout's Avatar
All were 1/4 watt excluding the power suppy resistors which were 2-5 watt.
Mind you everything there is still subject to change during prototyping, This was the original draft.
Gene
Guitar Headphone amp with distortion schematics jman 31 Headphone Systems 7 3rd March 2009 02:10 PM
Output of preamp drops when overdriven oliverwestby Tubes / Valves 7 1st February 2009 02:36 PM
How long will an overdriven LED last? EWorkshop1708 Power Supplies 14 11th May 2008 04:39 AM
6BQ5/EL90 guitar amp schematics wanted PRNDL Tubes / Valves 9 9th June 2007 05:52 PM
Has anyone easy Guitar-tubepreamp schematics? duff987 Instruments and Amps 4 6th October 2005 04:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
