Adams Amp Discussion, please help! :) - diyAudio
Old 18th March 2005, 08:12 PM   #1
9am53 is offline 9am53  Canada
Send a message via MSN to 9am53
Default Adams Amp Discussion, please help! :)
Hello, I finally got a copy of the schematic for my amp scanned...here is a piece of it:
What I want to do is replace the auxillary volume pot with just a normal 1 meg pot and use an aux input as a separate channel. Next I want to put the master volume just after the plate of V1B. Would the master volume pot be the same? and would I just connect the mic volume output to the grid of V1B? Any suggestions would be helpful
Guitar is Good
Old 21st March 2005, 02:48 PM   #2
Angry grrrrr......
grrrr........
Guitar is Good
Old 21st March 2005, 09:51 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi 9am53
Nice tube. Reminds me of a Bogen amp schematic.
-Chris
Old 24th March 2005, 02:23 PM   #4
yeah, it is a Bogen CHB20A...do you have any suggestions about the stuff I proposed in the first post of the thread?
Guitar is Good
Old 24th March 2005, 05:25 PM   #5
any suggestions abaout my proposed modifications? will my ideas work or are there any major flaws with my ideas? I dont want to start cutting and soldering only to find out I messed something up...
Guitar is Good
Old 25th March 2005, 01:25 AM   #6
anatech's Avatar
Hi 9am53,
What are you trying to accomplish? You need the extra gain V1a gives you for the mic. Are you trying to make a mixer?
From what you have said, I'd use the circuit as is. You can replace the AUX pot with a single 1Meg if you don't like the way it works now.
-Chris
Old 28th March 2005, 02:45 PM   #7
Ok, I guess I could be more specific...I would just like to make a simple guitar amp...not a mixer of any sort. I was thinking I could use the mic channel as a "hotter" channel, and the aux channel as a quieter channel...but I have never done this before, so I have no clue if I can use the aux channel as a guitar channel...let alone what it would sound like. I dont really need the second channel at all, so I think I will start off with just the mic channel. Also, I read in an article "converting PA amps into Guitar amps" that the master volume should go after the second amp stage, that is why I want to move the master volume.
Guitar is Good
Old 29th March 2005, 12:03 AM   #8
anatech's Avatar
Hi 9am53,
You need high gain for both the mic and pickup. You do not want to move the master behind the tube because you are driving the tone control ciruit from there. It looks like you need to add a tube stage before that point.
-Chris
Old 29th March 2005, 03:24 PM   #9
Ohh I see, so I need a tube section before every individual circuit...ie, I cant have the tone circuit and a volume control next to each other without a tube section in between. Cool, thats not a problem at all. So from the sounds of it I just need to change my tone stack to be more suitable for guitar... Can I use the mic volume as a pre-amp volume? Speaking of which, can I keep the 1 Meg pots for the volume controls, or will I have to replace them? thanks for all your patience and help
Guitar is Good
Old 31st March 2005, 01:10 AM   #10
anatech's Avatar
Hi 9am53,
The best thing for you do do is check out a bunch of Fender schematics, Hiwatt or Marshall. Whatever. After looking at these I thing you'll have a very good idea on how to do this. You are on the right track. I forsee success in your future.
-Chris
John Adams, Harmonium eStatic Music 4 8th February 2008 04:15 PM
Car HU Discussion fr0st Digital Source 4 11th March 2004 07:42 AM
Copyright 1999-2017 diyAudio
