line-stage preamp tubes? which ones to use... - Page 2 - diyAudio
Old 17th March 2005, 02:39 PM   #11
richwalters's Avatar
Originally posted by mark_titano
because the lower heaters current it is useful in order to avoid humm problems, large loop areas and and electromagnetic connections.
It is cheaper too...
What is your opinion?
Hi there........arguement not valid if DC heater supply is used...as for electromagnetic connections....that's a new one on me.....I'd always thought the mains tranny was the culprit....perhaps I've misunderstood the 50 Hz wavelength.....
richj
Old 17th March 2005, 09:55 PM   #12
6BM8 in STC mode sounds to SS-like, huh?....
My guess to why it sounded SS is maybe because I used a discrete transistor? Didnt have a 6AK5 on hand at the time, which is what the original circuit had, so went with it the transistor instead.
http://www.ne.jp/asahi/evo/amp/6bm8/zu2.gif
Maybe I should try to find a tube to use as a driver instead. Eli had a good thought, though. But, whats with the 6V battery?
Old 18th March 2005, 12:10 AM   #13
RD,
The battery is for grid bias. You cap. couple at the I/P, use a 1 MOhm grid resistor, connect the "bottom" of the grid resistor to the - side of the battery, and connect the + side of the battery to the triode's cathode. Connect the small load resistor between the cathode and ground. By using battery bias, you avoid calculations and get good bass. 6 V. of bias cleanly handles a 2 VRMS I/P signal, as produced by a CDP.
A final point, connect the O/P of the source selector switch to the "top" of the volume control and ground the "bottom" of the volume control. The wiper of the volume control connects to the CF I/P cap. Use any volume pot. you like that's 100 KOhms or less.
Eli D.
Choosing the line stage preamp. felixx Tubes / Valves 3 22nd September 2006 06:54 PM
Best line stage preamp to mate with the Zen v9? jimmyd53 Pass Labs 4 19th June 2006 11:45 PM
Passive line stage with tubes Glowbug Tubes / Valves 6 17th March 2006 03:14 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
How to modify Aleph ONO to line stage preamp aht Pass Labs 2 11th January 2005 01:31 AM
Copyright 1999-2017 diyAudio
