Different direct heating styles?
Old 14th March 2005, 02:42 PM   #1
ktkammon is offline ktkammon  Finland
Default Different direct heating styles?
What are the main advantages/disadvantages of these two heating schemes?
Old 14th March 2005, 03:06 PM   #2
hacknet is offline hacknet  Singapore
the one with the resistors is supposed to in some way reduce the hum. i`m not really sure how it works, coud someone shed some light?
Old 14th March 2005, 08:12 PM   #3
jeapel is offline jeapel  Canada
hi
just my practical experience with my last tube driver
but no exact explication
www.loginnovation.com/jeapel
with 6sn7 double triode half for right and half for left
1-without ground on heater big hum on speaker
2-with one ground zero hum on right and hum on left
3-with 2 100 ohm 1w very low hum on both channel :-)
4-for my very low gain 6as7 no need of ground
100ohm 1 w is typical value my 6sn7 are low noise
electro harmonic but a cheap hummy tube maybe
50 ohm or 25 ohm with good watt
Old 14th March 2005, 08:45 PM   #4
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
1 is for AC heaters where the alternating voltage balances between the two nodes, minimizing grid-cathode hum. 2 is for DC filaments.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 14th March 2005, 09:50 PM   #5
"2 is for DC filaments."
maybe but old radio use methode 2 with ac
and there is no big hum ??
Old 15th March 2005, 12:14 AM   #6
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
With indirectly heated tubes and quite likely a center tapped heater xformer too....
Frank
Old 15th March 2005, 01:22 PM   #7
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Nice amp! Got any pics? How many watts does it produce?
Back on topic, I have found most indirectly heated tubes have quite minimal hum.
Raising the heater supply above ground by a few volts, keeping in mind heater to cathode ratings, can also reduce hum. This is often necessary in SRPP-type designs.
Old 15th March 2005, 08:55 PM   #8
i just finish my web site with photo
Different direct heating styles?Hide this!Advertise here!
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 05:43 PM
MOSFET heating on my amp... thefish Class D 16 30th March 2008 09:28 PM
Direct heating triodes are really better? Jaime Tubes / Valves 22 8th September 2006 03:40 PM
heating kathodyne Tubes / Valves 3 2nd September 2005 01:49 PM
Tubes and music styles Simpleton Tubes / Valves 8 24th May 2005 03:33 AM
Copyright ©1999-2017 diyAudio
