diyAudio Sponsor
Old 14th March 2005, 05:41 AM   #1
IVX is offline IVX  Russian Federation
IVX's Avatar
Default Sample/hold DC servo circuit
hi,
I've started tube/mosfet differential buffer project, which need for the DC servo circuit, but i heard from high-end people that DC servo affect sound quality anyway, if very slow reaction even. Will be the deal better if i'll do measuring/regulating discrete and only 1 time for each 60s(ie. for 1-3 minutes just a hold last value)? Sapmle/hold with switched cap seems will work nicely and not so much complicated. Thanks for any advices!
Best regards,
E1.
Old 14th March 2005, 06:31 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
If you choose a high quality opamp, I think the sample and hold will give you more disturbance. I have used lately AD8620 and this is not a bad opamp
/Per-Anders (my first name) or P-A as my friends call me
Old 14th March 2005, 06:41 AM   #3
I agree with P - A, output of DC servo make in circuit " virtual ground ", connected in parallel to feedback loop. If you use at this position high quality opamp, degradation of sound quality is insignificant.
Old 14th March 2005, 07:10 AM   #4
IVX's Avatar
Holding for more then one minute, do you think that's necessary? BTW, probably bigger cap cheaper solution vs ad8620.
Best regards,
E1.
Old 14th March 2005, 07:44 AM   #5
IVX's Avatar
Yeah, if the DC servo is slow enough and low frequency noise also, then degradation of sound quality is insignificant.
IMHO, it will be better then nonpolar BG in the feedback pass anyway, but I have decided, that sample and hold will be more solid argument vs ordinary continuously regulating DC servo.
Best regards,
E1.
Old 14th March 2005, 08:01 AM   #6
peranders's Avatar
Each time you sample you will get a step out and depending of how much it is and the rise time you will maybe hear it. How about the S/H circuitry? Far more complex than a single opamp.
The servo speed should be around 0.5-3 Hz I think and this will mean that some signals will slip through up to 100 Hz and a very very very small part up to 1 kHz. AD8620 has extremely good performance up to 1 kHz and up 100 Hz the sonic impact is virtually zero and especially if you compare to the tubes.
Old 14th March 2005, 08:44 AM   #7
IVX's Avatar
Schematic, well, i think HC4016(though leakage is too much) +J-FET QUAD(e.g. opa4134) opamp and passive something.
Best regards,
E1.
Old 14th March 2005, 08:08 PM   #8
IVX's Avatar
Oops, seems the leakage is too much for multiplexer and for opamp also.. 60s hold gave several millivolts ripples, so choice is a continuously regulating or a digital solution.
Best regards,
E1.
sample-hold circuit_Sony 557ESD Mikewong Digital Line Level 1 16th June 2009 03:50 PM
Please explain a servo circuit ppcblaster Chip Amps 6 18th June 2007 12:02 PM
Mono DAC using sample/hold circuit for stereo mr_push_pull Digital Source 0 29th September 2006 07:35 PM
CDM 9 and servo circuit experts? tubenut Digital Source 8 1st April 2005 12:53 AM
Repair a servo circuit of TEAC VRDS 7 kwen10 Parts 0 14th July 2004 10:36 PM
Page generated in 0.07528 seconds (84.35% PHP - 15.65% MySQL) with 10 queries
