The most simple tube preamp
Old 8th May 2006, 05:34 AM   #11
Tyimo is offline Tyimo  Hungary
Thank a lot PHN!
I'm planning to build this too!
Greets:
Tyimo
Old 8th May 2006, 07:41 AM   #12
Simpleton is offline Simpleton  Portugal
Tyimo,
That circuit used to be on the Svetlana website, now down
I'm using it as a pre-amp stage directly feeding a SE 2A3. Sounds very nice, though it doesn't have enough drive to full power. But who cares?
"There's something organic about a happy cloud of electrons" - Neutron Bob
Old 8th May 2006, 12:45 PM   #13
phn is offline phn  Sweden
phn's Avatar
Another interesting tube to look into is the C3g.
I can't help you with schematics. But it's a great tube. Ideal for a phono headamp. Then add the cool-looking AZ50 rectifier. It's as much overkill as the GZ34 for an E80F pre. Like if DIY has anything to do with restraint.
Simpleton,
Would you like to elaborate on not enough drive? This, as mentioned, is my first tube project, and only because I haven't found any other alternative. I would much rather buy a vintage preamp and tweak it. (I'm a bricoleur rather than a DIYer.) But vintage preamps tend to be anything but great. Or they are ridiculously overprised like the Marantz Model 7.
And I do have some issues with the gain. 1:10 would have been more to my liking. I have a vintage amp and it only needs about 500mV.
Old 8th May 2006, 01:50 PM   #14
Default EF86 line amp
Hi and thanks for the help!
I would like to use the preamp with ca. +100V. Could you tell me how big will be the voltage gain and the max RMS output voltage?
I need "only" 15 V RMS, so I tought the 100V would be enough.
One more: Could you suggest a good, but simple PSU for the amp?
Greets:
Tyimo
Old 8th May 2006, 02:43 PM   #15
Phn,
By enough drive i mean that it puts around 30Vrms when i need some 40Vrms to full 3W output from the 2A3 (this from memory, it's been some months)
Tyimo,
I can't make the calculation right now, but you'll get more than 15V out at 100V, don't worry
For a PSU, get a diode bridge rectifier, 2 transfomers, one 220/12V and teh other 220/6V, connected back to back (220V/6v-12V/220V), plus 440uF of capacitance and you're done with a little over 100V (maybe 120~130V or so). Shouldn't be too noisy.
Old 8th May 2006, 06:46 PM   #16
Thaaanks Simpleton!!!
Greets:
Tyimo
Old 8th May 2006, 07:07 PM   #17
phn's Avatar
Thanks, Simpleton.
Old 16th May 2006, 06:58 AM   #18
sorenj07 is offline sorenj07  Germany
sorenj07's Avatar
the Shure M65 is a pretty simple preamp, it can be run in either line or RIAA mode
http://www.audioorigami.co.uk/Floppy...pyDIYMotor.htm
Old 19th May 2006, 04:37 PM   #19
kt88music is offline kt88music  United States
Your design looks good to me.
Old 20th May 2006, 06:23 AM   #20
sorenj07's Avatar
whoops - wrong link
here it is...
http://www.diytube.com/phpBB2/viewtopic.php?t=968
The most simple tube preampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Simple tube preamp? picklgreen Tubes / Valves 10 11th February 2007 11:11 AM
Simple Low Voltage Tube Preamp? CarlosT Tubes / Valves 11 1st February 2007 10:25 AM
Newbie want to build simple tube preamp&psu!need help! thomgun_lc Tubes / Valves 55 29th November 2005 02:08 PM
Simple tube preamp... chrille Tubes / Valves 8 18th February 2003 09:44 PM
Copyright ©1999-2017 diyAudio
