diyAudio Sponsor
Old 12th March 2005, 11:08 PM   #1
Default suitable preamp for a tube amp (kt88+12ax7)
Hello, I am totally new for tube amp. Just brought a tube amp 40wch, with KT88 + 12AX7. I really don't know how to choose a "suitable" preamp for it. What makes a preamp good? Should I look for tube preamp or ss preamp? what's their difference? My budget is $300-$500 (for used). Thanks for input
Old 13th March 2005, 12:15 AM   #2
Sherman is offline Sherman  United States
Default Re: suitable preamp for a tube amp (kt88+12ax7)
I think for your amp any good preamp with a gain of 4 to 6 would probably work just fine. You need to decide on what features you want/need such as input selectors (some may have only a single set of inputs), phono stage (rare these days as a built-in feature) etc.
If you are looking to build one yourself the Bottlehead Foreplay kit would be a good choice. A ton of them have been built and there is a large community of builders/users to turn to for help and ideas on mods.
Also Lighthouse Electric has a suitable preamp kit the STA-1LG for about $100. With the LE kit you have to supply the chassis. I built one this winter and it had a fairly annoying 60 Hz hum but I converted the heaters to DC (not a bad idea for a preamp anyway) and the hum is gone. It now drives my KT88 SE monoblocks quite nicely.
--Sherman
Old 13th March 2005, 02:48 PM   #3
should I look for tube preamp or ss preamp for the KT88? thanks
Old 13th March 2005, 03:59 PM   #4
Yeah, not very specific about which was best was I? But honestly it depends on whether you intend to build or not. If you want something already built you have a lot of options but not quite as many as if you will build it.
The "tube sound" will still be there if you use a SS pre but I just like the idea of tubes end to end. If I were you I would build either the Bottlehead Foreplay or the Lighthouse Electric STA-1LG.
--Sherman
Old 17th March 2005, 01:38 AM   #5
how important is the preamp in the whole system? will a good or bad preamp make how much the sound better or worse? thanks
Old 17th March 2005, 03:05 PM   #6
That actually depends a lot on the power amp and how much gain you have to get from the preamp in order to drive the power amp. A bad preamp can make a good power amp sound bad but a good preamp can't make a bad power amp sound good.
I would say one of the most important things a preamp can do (or actually not do) is hum. Any hum from the preamp will be amplified by the power amp so it is important to have a quiet preamp. Most power amps don't require a lot of gain from a preamp, so a preamp with a gain from unity to maybe 6 should be fine.
Another function of many preamps is input source selection. If you regularly listen to more than one source (I use a tuner, CD player and turntable) it is nice to be able to switch between sources without having to change interconnects around.
--Sherman
Old 17th March 2005, 03:22 PM   #7
dshortt9's Avatar
Here is a quick suggestion:
http://cls.audiogon.com/cgi-bin/cls....ube&1115915942
2x 12AX7 preamp fuse value gottlieb Tubes / Valves 7 18th May 2009 04:29 AM
12AX7/12BH7 Hammond Tube Preamp Project jordankersten Tubes / Valves 4 5th April 2009 03:49 AM
12ax7 preamp. longji98 Tubes / Valves 20 13th September 2008 06:06 AM
12ax7 preamp Antonix Tubes / Valves 4 17th November 2005 03:52 PM
12ax7 preamp,need help. digi01 Tubes / Valves 13 12th April 2004 08:00 AM
Page generated in 0.11397 seconds (80.09% PHP - 19.91% MySQL) with 10 queries
