I ran across a table light that uses tubes from Moth Audio and another from Mod Loft in NY. I'd like to DIY my own light with about 6 tubes, anyone know of a kit or published schematics for such a beast?
thanks Christof |
#2 |
it shouldnt be hard. just find some tubes that you like and wire up the heaters.
#3 |
Try this one!
tube nightlight |
#4 |
hi , there was one published in a HI-FI- WORLD DIY supplement a few years ago using a 211 tube very simple, like some one else posted earlier just wire up the heater of any tube....... even though the tube is dead the heaters should work l tink! cheers TC
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#5 |
an 0D3, a clamper circuit, and a current limiting resistor?
should be able to run for years without blowing up, and a little more efficient than using a tube with a heater. |
#6 |
OA3 and 0.47 uF capacitor in series as a current limiter (Use 0.22 for 240V).
Use ONLY an AC line rated capacitor (X-cap), which will have safety agency marking (UL, CSA, VDE, etc.) |
#7 | |
OMG GACK! Eh, you can clean up the pieces when you turn it on during a sine wave peak. |
#8 |
So anyway yeah, run any 0x2 or 0x3 type like a neon tube with a series resistor. 0A3 is preferred for the neon. 0G3 is neon but fully silvered inside, you'll have to find worn out ones to see much glow.
Filaments don't do much light but any tube with a lot of exposed cathode or filament will be nice. 6AS7 comes to mind. You'll spend a good 15-20VA though. |
| Class-A tube amps deprecated in the light of global warming? | wakibaki | Everything Else | 69 | 27th March 2008 05:34 AM |
| Night dreaming? / Middle of the night bloom | Gabevee | Tubes / Valves | 54 | 25th July 2004 04:36 AM |
| hardcore tube night light? | karma | Tubes / Valves | 4 | 2nd July 2004 10:13 AM |
