Sprague capasitor id
Old 12th March 2005, 07:30 PM   #1
morfeas is offline morfeas  Greece
Default Sprague capasitor id
Could someone please id the following capasitor type? PIO, Polyprop ...
Got my hands on a few of them. Missed a few hundrend more thou.
Common sense is not that common.
Old 12th March 2005, 07:31 PM   #2
One more
Old 12th March 2005, 07:46 PM   #3
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
vitamin Q?
http://www.cypress.ne.jp/kouchi/cap.htm
Old 12th March 2005, 07:52 PM   #4
Tekko is offline Tekko
Banned
I think it means 1µF 300VDC
Old 12th March 2005, 09:29 PM   #5
SmarmyDog is offline SmarmyDog  United States
SmarmyDog's Avatar
The threaded end makes me think is a feedthrough capacitor. Measure the resistance (yes resistance, not capacitance) across the two ends. If it remains basically zero then it is a feedthrough type and the 1uF is between the conductor that runs from one end to the other and the case. It is used to filter RF from a signal passing to or from a shielding enclosure.
-Casey Walsh
Old 12th March 2005, 09:39 PM   #6
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Casey knows his business.
I use such feedthrough filter caps on my cars, shaffner's.
Look identical, except for the brand.
Shaffner's are worth $0.50 here.
A lot of them are used in the telecom field.
Old 13th March 2005, 09:48 AM   #7
Measurments
Pin1 2 Pin2 1uF/Open
Pin1 2 Case 0uF/Open
Pin2 2 Case 0uF/Open
The question is what type/material is it? Polyprop, PIO, Teflon?
Old 13th March 2005, 11:44 AM   #8
i am not an expert on Sprague, but my guess is that these caps do not differ that much between manufacturers.
A Siemens/Epcos feedthrough has a metalised polypropylene di-electric.
Such caps are made up till 4.7uF.
See www.epcos.com keyword B85121
Could also be oil impregnated paper.
Sprague is Vishay owned, you could check www.vishay.com
Sprague capasitor idHide this!Advertise here!
FS: Panasonic 22UF, 63V SMT capasitor gabanyayaya Swap Meet 0 10th May 2009 11:31 AM
krell ksa 50 capasitor help needed beckypumps Solid State 26 20th January 2006 07:57 AM
capasitor tze-hao yen Pass Labs 0 5th March 2005 03:20 AM
capasitor arold19 Pass Labs 21 17th February 2003 04:04 AM
