Please confirm my transformer math. - diyAudio
Old 10th March 2005, 11:52 PM   #1
leadbelly's Avatar
Default Please confirm my transformer math.
The background is that I have some old output transformers that came out of an SS amp, VERY old. They are 2500 ohm primary / 3.2 ohm secondary. They look like they could be used in a spud amp because they are reasonably large, say at least an inch in every dimension (I don't have them with me right now). So the 6C45Pi is suited to a 5K primary OPT. From RDH4 (attached image) it looks like using an 8 ohm speaker would offset the drop in primary resistance WRT distortion. Is that correct?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 10th March 2005, 11:58 PM   #2
jeff mai's Avatar
Default Re: Please confirm my transformer math.
Originally posted by leadbelly
Is that correct?
Yes, but it isn't the only consideration. The primary inductance of the trans may not be sufficient to ensure full bass extension.
Old 11th March 2005, 12:01 AM   #3
leadbelly's Avatar
Default Re: Re: Please confirm my transformer math.
Thanks! Yes, I fully expect this to be bass-challenged amp. I was more concerned from a will-work/won't work at all point of view.
Old 11th March 2005, 01:45 AM   #4
frugal-phile(tm)
planet10's Avatar
Those should also work with 50EH5...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th March 2005, 01:55 AM   #5
I hate to be a spoilsport, but a cautionary note is in order. Trafos designed for use with BJTs have insulation that can tolerate battery voltages. It's quite possible that the insulation in those old trafos will break down when the CT is connected to a tube B+ rail. Don't forget that the lamination stack will be at ground potential.
Eli D.
Old 11th March 2005, 02:47 AM   #6
leadbelly's Avatar
So if I ran a long burn-in session with a small fuse in series with the primaries, wouldn't that address that issue?
Old 11th March 2005, 04:00 AM   #7
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Go for it. Put a fuse in the power supply and hope she doesn't blow up.
edit:
Oh, you're in alberta eh?
Im in saskatoon. email me or something.
Old 12th March 2005, 12:52 AM   #8
leadbelly,
Those old SS trafos are constructed for low voltage service. I get no comfort from a fuse.
There is a SURE FIRE way to be safe. Build your amp with parafeed topology. CCS load the plates and cap. couple the plates to the O/P trafos. Ground the CTs of the trafos.
Eli D.
Can someone confirm this xover layout? xyrium Multi-Way 4 24th October 2005 03:43 AM
DCX2496 Level Problem...how to confirm ultrachrome Digital Line Level 19 8th October 2005 11:13 PM
Can somebody confirm this calculation? Eton Multi-Way 2 12th December 2003 06:16 AM
Fred D... can you confirm this... MWP Digital Source 3 24th May 2003 06:31 AM
Copyright 1999-2017 diyAudio
