6Vdc from 6,3Vac
6Vdc from 6,3Vac
Old 4th April 2005, 11:22 PM   #21
audiousername is offline audiousername  Australia
audiousername's Avatar
Originally posted by resident
How much must be the total resistance of the voltage divider?
R1+R2= ?
Up to you; it isn't exactly critical. Just make sure that it doesn't pass so much current that it produces too much excess heat. Size it appropriately, and the potential divider will also be an effective bleeder.
With cathode followers, the load is simply moved to the cathode circuit, and the signal taken off between the cathode and the load.
Jason
Old 5th April 2005, 02:06 PM   #22
resident is offline resident
Account Disabled
Jason,
thank you for your answer.
My design isn't a CF but I suppose that.... it's up to me....
I have done some searches on internet and I saw that around 200K is OK.
6Vdc from 6,3VacHide this!Advertise here!
DC PSU for both 6.3vdc and 5vdc from one 6.3vac transformer? sgerus Tubes / Valves 0 29th February 2008 05:47 PM
6VDC Wall worts, 2 amp... chipco3434 Chip Amps 2 11th December 2007 05:10 AM
Aleph30 PSU - +v/-V .6vdc difference hifimaker Pass Labs 7 1st March 2006 05:16 PM
6,3VAC to 6,3VDC marijan Tubes / Valves 5 11th June 2005 07:20 PM
