baxandall tone control - Page 2 - diyAudio
Old 12th March 2005, 10:40 PM   #11
9am53 is offline 9am53  Canada
Send a message via MSN to 9am53
Hey thanks alot, I thought that I could just change some values to modify it for tone. I stil have some work to do on the4 amp before I actually hook the circuit up. I have a Bogen CHB20A 20 watt PA that I am convertting to a guitr amp. I will look into it and let you know how it went.
Guitar is Good
Old 12th March 2005, 11:23 PM   #12
Default Just as a matter of interest,
...do you guitar players out there twiddle with the tone controls a lot, or do you find a sound you like & stick with the same settings?
(my amp has only a volume control, so I don't have any choice....must get around to that pre-amp some day...when I do it'll probably only have Treble boost & overdrive...)
Pete McK
Old 13th March 2005, 10:08 AM   #13
benny is offline benny  Australia
benny's Avatar
Send a message via MSN to benny
Default Re: Just as a matter of interest,
I personally twiddle quite often, at home I tend to leave it, but when giging I twiddle for (hopefully) obvious reasons.
I also use a Baxandall tone stack in the clean channel in my main amp. Mind you I'm mostly playing jazz and a good jazz tone tends to use a fairly different aproach to most other styles, you just have to hear the charachteristic sound of a good jazz pickup and compare it with most other pickups to tell. In the dirsty channel I use a fvm tone stack (based more on a Marshall, but modified a bit) to provide the basic tone, but in one of the following stages I placed a baxandall tone stack for more control. I've found this set up, while inefficient, gives extremely good results.
Connecting your ground leads to the chassis should hopefully work fine... if it doesn't then you need to do something about grounding the chassis asap...
Old 15th March 2005, 02:29 PM   #14
Default Re: Re: Just as a matter of interest,
Personally I dont tend to mess around a lot, I just "set it and forget it" to quote Ron Popeille. I want the circuit to be efficient, I dont want to drill more holes in the control panel of the amps chassis (so the fewer knobs the better), and I would like more control over the tone. This is why I wanted the baxandall... I am leaning towards the baxandall again, but I still have some time before I start the process of installing it, so keep the messages coming.
Guitar is Good
Old 15th March 2005, 02:34 PM   #15
Hey, for anyone who has any experience with tone stacks...I love hendrix clean tone, hendrix nasty tone, and friedman metal "tone", I will be playing a strat for the most part. What stack do you recommend that can be effective for adjustments in thosesound styles? any and all comments will help.
Guitar is Good
Old 16th March 2005, 07:21 AM   #16
This thread looks like it's pretty well played out, but here's my take on the two tonestacks.
First, all stacks have an insertion loss. Any boost or cut is measured against the insertion loss, generally when the controls are set to flat response.
Having said this, the Fender stack is a boost only stack. That is, when treble and bass are set to minimum, the response is basically flat. You can only boost them from there. This leaves a midrange notch. The midrange control changes the depth of this notch.
The frequency of the notch is typcally set around 400Hz (if I remember right) because this seems to work with the spectrum of the guitar sound.
The Baxandall (or really, I think what most people mean is the James) stack, can boost and cut the treble with respect to the flat response. Boost leaves the notch and cut leaves a peak at the midrange.
The midpoint in this stack is typically set around 1KHz because this seems to suit audio listening best.
Based on what I know, you can't make the Fender stack cut bass and treble, although you can play with the midpoint frequency.
The James stack can be configured in alot of ways, some with lots of boost/cut, some with much smaller amounts.
Old 16th March 2005, 06:44 PM   #17
A small wording correction:
The Baxandall (or really, I think what most people mean is the James) stack, can boost and cut the bass/treble with respect to the flat response.
Old 20th September 2014, 05:34 PM   #18
Lyford is offline Lyford  South Africa
Absolutely riveted by you guys and the dynamics of the posts. I'm a newey, ( signed on 2014/09/20 ) and I'm installing an active circuit in my custom Strat using a TL072 to isolate the inductive pups from the capacitive cable between amp and guitar. I am considering re configuring the three Pots as Volume treble and bass. With the pups looking into infinity and negligable loading it should liberate top end harmonics, I will use a baxendall tone stack to start with because all I need is a flat response with pots set central and the option of +/- 10dB of swing either way. Those of a more erudite persuasion might like to comment, if so please do. Lyford
Old 20th September 2014, 07:01 PM   #19
Originally Posted by runeight View Post
The Baxandall (or really, I think what most people mean is the James).....
Just in passing, and not commenting on relative merit, but I am a little surprised that there could be a misunderstanding between "James" and "Baxandall" topologies.
The "James" is clearly a passive circuit (only) needing log law controls, as distinct from the "Baxandall" is the feedback version round a tube (only), using linear controls. Characteristics of boosting, attenuation, slope etc. can be chosen to suit and is not a particular feature of either. The only slight advantage of the Baxandall is in stereo amplifiers, because in practice linear controls usually track more accurately than log ones.
As said I am not arguing for specific tonal characteristics preferred by guitarists, those are the preference of the instrumentalist. I simply suggest that the correct name be used.
Old 2nd July 2015, 07:46 AM   #20
Default Tone controls
Originally Posted by 9am53 View Post
Thanks a lot guys, I am going to use the old f/v/m circuit, now I just have to figure out how the rest of the amp works!
Hi. Enzo is also right. There is nothing bad about baxandall. I have used many of these, and from the two transistor baxandall ckt as given in the Philips audi book, to even the one transistor versions. Yes that brings up another point. The first transistor buffer is vital, other wise it changes volume when you use the Bass or Treble controls. There are other interesting baxandal circuits also, which work very well. Like the ones using LF 351, 353, 356 high slew rate amplifiers. These are found in Nat Semi application book. They have a third pot with midrange, and that also works well. remember, for simplicity they have not shown the preceding transistor buffer, but include it. it is a simple emitter follower. if you use the op amps, the slew rate is important. minimum 10V/ uS. if using transistors, use the correct specced ones. Hope this helps.
Baxandall active tone control jenks Solid State 3 18th April 2008 09:18 PM
How can I integrate a Baxandall Tone Control roger-k Solid State 9 16th July 2007 10:33 AM
3 band tone ,BAXANDALL ????? bass treble mid????? prorms Solid State 0 4th September 2006 05:23 AM
Baxandall Tone Control zee Parts 3 22nd December 2004 01:11 AM
Feedback resistor on Baxandall tone stack? porkchop61 Tubes / Valves 3 10th October 2004 02:39 PM
Copyright 1999-2017 diyAudio
