diyAudio Sponsor
Old 8th March 2005, 05:11 PM   #21
frugal-phile(tm)
planet10's Avatar
Originally posted by rdf
Maybe it's a technique better suited to push-pull AB than single ended class A?
It is likely that Bill has never built an SE amp in his life. He is a big PP fan.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th March 2005, 05:37 PM   #22
SY's Avatar
Percy, no, the 43% DC comment referred to another amp design where the designer asserted that not only should the AC be applied to the screen at a 43% ratio, but so should the DC. Sorry, didn't mean to confuse.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th March 2005, 10:17 PM   #23
smoking-amp's Avatar
Try something like this to make ultralinear really linear and see what the screen really needs on it. Then can decide if a UL tap signal comes close or if any passive fix ups can help.
Don
Ohms Law V = I R
Triode strapping a 6V6 (or any tetrode/pentode, really) Nihilist Tubes / Valves 6 23rd February 2009 09:54 AM
Triode strapping a tetrode... nickds1 Tubes / Valves 25 1st January 2009 11:36 AM
triode strapped tetrode nhuwar Tubes / Valves 2 2nd February 2008 09:14 PM
Triode strapped tetrode nhuwar Tubes / Valves 5 7th May 2007 01:08 PM
Tetrode or Pentode? / Tube info FrankRoss Tubes / Valves 15 25th March 2004 01:24 PM
Page generated in 0.07806 seconds (70.91% PHP - 29.09% MySQL) with 11 queries
