Proof that demagnetizing tubes works - diyAudio
Old 5th March 2005, 01:22 AM   #1
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Proof that demagnetizing tubes works
I've started a new thread on this, as this new visual proof that demagnetizing tubes has a significant effect in reducing the noise floor of the tube, thanks to John Swenson from Audio Asylum for the effort he's put in to get conclusive proof that demagnetizing tubes works.
http://db.audioasylum.com/cgi/m.mpl?...DT&r=&session=
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 5th March 2005, 02:09 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Now remagnetize it and complete the proof. Also, make note of the values of noise and distortion reduction, and run controls.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 5th March 2005, 02:36 AM   #3
georgehifi's Avatar
What blows me away is up to 36db of noise difference around the 3k and 10k mark. For those of you who did'nt realize the db scale is over on the right, (use the horizontal slider).
I demaged my tubes using the simple Radio Shack tape head demagnetizer, they can be found on ebay second hand for around $5.00, take the tube out stand it upright on a table and circle it half a dozen times slowly spirling upwards till your 6 or so inches away from the top of the tube, keep it about half an inch away from the side of the tube as your doing it as i think that touching it maybe too close.
Cheers George
Old 5th March 2005, 03:34 AM   #4
Send a message via AIM to DigitalJunkie
Hmm... Curious..
Old 5th March 2005, 05:45 AM   #5
audiousername's Avatar
This data has been discussed here previously. I'll try to dig up the thread then post a link.
Jason
Old 5th March 2005, 06:03 AM   #6
After digging through 20 pages of SY's posts, here 'ya go.
Jason
Old 5th March 2005, 06:05 AM   #7
georgehifi's Avatar
Yes it has Jason, but not the link to the at the startof this thread , if i posted it in the other thread it would have been buried at the end of 44 posts. Anyone got any opinions on this?
This is a very enlightening graph(study) that John Swenson has measured, and i belive that it deserves a re-discussion, as too many doubters poo bared it without any proof of the contrary in the old post that i started about it.
This new one has had 95 reads in 2 hours, that's got to be proof of being popular for some to read. Even the doubters.
Cheers George
Old 5th March 2005, 06:11 AM   #8
Yes, it does seem to be popular.
You must note that the 6AR8 is a beam deflection tube, and is far from the average audio valve. It would not surprise me if that this particular valve is sensitive to magnetic fields deflecting the electron beams within it.
Even if it is proven that it is measurably beneficial for the 6AR8 to be demagnetised, the result cannot be generalised to all valves.
Jason
Old 5th March 2005, 06:28 AM   #9
georgehifi's Avatar
From what i've read of his posts on this tube(6AR8), it's used in his BDT Preamp which is comparable to the very nice but expensive Melos preamps, and his test on demagnitization are using audio frequency from 20hz to 20khz.
So it looks as though this tube can be used in audio.
Cheers George
Old 5th March 2005, 06:31 AM   #10
I do not doubt this valve this can be used for audio. Heck, you can whip up a volume control with a hexode if you felt like it.
My point was that the internal construction is atypical of common audio types, and the results from any investigation into the demagnetisation of 6AR8s cannot be generalised to all valves without further investigation.
Jason
Demagnetizing tape heads DragonMaster Analogue Source 40 14th June 2011 01:04 PM
Proof that RAW is crazy... seangoesbonk Multi-Way 6 24th January 2003 01:34 PM
demagnetizing (mr. feedback question) Fred Dieckmann Everything Else 44 4th November 2002 11:34 PM
Copyright 1999-2017 diyAudio
