Interstage trans? Yes please!
Old 2nd March 2005, 08:52 AM   #1
Gluca is offline Gluca  Italy
Gluca's Avatar
Default Interstage trans? Yes please!
Ciao belli,
I am messing about with this PP idea. Any suggestion for the interstage trans?
Gianluca
Old 2nd March 2005, 09:06 AM   #2
audiousername is offline audiousername  Australia
audiousername's Avatar
You will quite likely find it very difficult to match the 6C45Ps
EDIT : Have a look at this thread.
Jason
Old 2nd March 2005, 11:39 AM   #3
Gluca's Avatar
That's very true. I'll give anyway a try. Should matching result impossible I'll revert to a single 6C45pi driver stage
Gluca
Old 2nd March 2005, 12:07 PM   #4
Brett is offline Brett
Brett's Avatar
Gluca
Good luck. I'd go for the 6C45 parafeed running a CCS into an IT w/o a gap for lots of inductance. Works well.
Old 2nd March 2005, 12:21 PM   #5
Peter Menting is offline Peter Menting  United States
You might take a look at the "Seth" monoblocks on the Magnequest site. There is a detailed write up on them that can be downloaded from the site. I am currently rounding up parts to build the Ralph Powers PP amp using the 6C45PI and a pair of interstage trans. from Jack at Electraprint.
Hope this helps.
Pete
Old 2nd March 2005, 05:13 PM   #6
Gluca's Avatar
@ Brett
something like this ???
@ Peter
what inter trans did you pick up from electraprint?
Any comment about the CCS/driver bias?
Gianluca
Old 2nd March 2005, 06:33 PM   #7
I have two of the 35PPG's on order to go from the plate of the 6C45 to the grids of the output tubes. (Still undecided whether they will be 6B4G's or 2A3's.
Am not planning on a CCS but that's just my choice, no knowledge of how it might affect the sound.
Pete
Old 2nd March 2005, 08:06 PM   #8
Brett's Avatar
@ Brett
No. Use the CCS as an anode load, cap couple the IT between the 6C45 plate and ground (or return it to the cathode). I have no way of drawing a cct for you, so here's Kurt Strains's 47PP prototype. Some of the component values were changed later, so just use it to see the topology.
Old 3rd March 2005, 12:12 AM   #9
Gary P is offline Gary P
Gary P's Avatar
A single ended stage will only work with the CCS on the plate. If you place a CCS on the cathode of a single ended stage it will force the plate current to be constant regardless of how much signal you drive into the grid. No change in current equals no gain.
The schematic above of Kurts variation of the 47P-P is the correct way to use a CCS in a single ended parafeed setup.
Gary
Old 3rd March 2005, 09:41 AM   #10
Gluca's Avatar
mmm thanks for the clarifications. I believe I will start with a simpler topology/tube. What about E88CC PP + IT + 2A3 PP?
Gianluca
Interstage trans? Yes please!Hide this!Advertise here!
For 45 > 845: selecting an 9.5/ 10 Interstage rick57 Tubes / Valves 1 8th July 2017 01:22 AM
45 -> 813 Interstage Steven-H Tubes / Valves 34 3rd February 2008 05:39 PM
Interstage X-former identification Klimon Tubes / Valves 0 14th October 2007 09:29 PM
4K:10K interstage astouffer Tubes / Valves 0 24th March 2005 05:34 PM
interstage coupling Raj1 Tubes / Valves 18 19th December 2003 06:28 PM
Copyright ©1999-2017 diyAudio
