Need help understanding transformer impedance ratios and impedance matching
Old 28th February 2005, 04:04 PM   #1
percy is offline percy  United States
Default Need help understanding transformer impedance ratios and impedance matching
I am a bit confused about impedance ratios and actual impedances of the primary and secondary of a transformer when it comes to matching a source to a load.
An impedance ratio of 10:1 is required - for matching a 10k load to a 100k source.
Now there are two transformers both having an impedance ratio of 10:1 but one of them is spec'd as having a 600 ohm secondary and the other with a 15000 ohm secondary. My understanding is that if I put a 10k load on either of these transformer's secondary, the primary will simply reflect a 10x (100k) load to the source.
Then what does 600ohm and 15000ohm mean ? What impedance is this ?
Old 28th February 2005, 04:49 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Transformers may have the same ratios but with different number of turns in both primary and secondaries. The more turns in the primary - the more inductance. Higher inductance will allow higher impedance of the driving source within the same bandwidth - in very simplistic terms if you don't have enough primary inductance you can't get good bass from a high impedance source. If the source is low impedance high inductance is no longer essential and better results in the high frequencies may be obtained with a transformer using less wire in the primary.
Many other factors are at play when choosing the best impedance for a transformer but this can give you an idea.
Old 28th February 2005, 05:09 PM   #3
so if bass, bandwidth and fidelity are not really important - (the load is a vintage heaphone with a very limited bandwidth anyway, and the source a crystal detector) - then either of these transformers should do ?
Old 28th February 2005, 05:42 PM   #4
analog_sa's Avatar
I have no idea. The piezo source is presumably high impedance, something like megaohm? And earphones are what, kiloohms?
Ooops, sorry i see you've given this data in your first post
Old 28th February 2005, 05:44 PM   #5
On Hiatus
SY's Avatar
Yes, either one will probably work just fine.
If you want a deeper understanding, check out the Radiotron Designers Handbook.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 28th February 2005, 09:35 PM   #6
Ok thanks, I will check that out...
analog_sa:
I think thats the DC resistance you're referring to. Piezo's are typically megohm and magnetics are ~2Kohm.
Just to satisfy my curiosity I measured the impedance of a piezo earplug and and also a pair of magnetic headphones I had lying around...
The impedance of the piezo drops as the frequency rises. It goes from about 25Kohm at 200hz to settle down to about 1Kohm from 5Khz onwards - like a capacitor.
The impedance of the magnetic phone rises with frequency. From about 2Kohm at 200hz to about 12k-16kohm in the upper frequency range.- like an inductor.
Acoustic measurements reveal a horrible frequency response - barely usable from 200hz to 3Khz.
Need help understanding transformer impedance ratios and impedance matchingHide this!Advertise here!
Impedance Matching maxzimum Solid State 2 9th April 2009 03:03 PM
Impedance matching transformer rhapsodee Pass Labs 15 18th January 2009 12:02 PM
Help with Impedance Matching mudihan Pass Labs 6 14th July 2006 11:35 AM
winding impedance matching transformer bbksv Solid State 8 7th March 2004 09:57 PM
Impedance Matching bryce66 Solid State 6 9th November 2001 10:02 AM
Copyright ©1999-2017 diyAudio
