Audio schematics for GU50 ???? - diyAudio
Old 28th February 2005, 03:40 PM   #1
felixx is offline felixx  Romania
felixx's Avatar
Default Audio schematics for GU50 ????
What do you think about GU50?
Good caracteristics and power in audio hi-end amps. or cheap tube?
Better than EL34 or 300B? Schemes?
Thank's.
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 1st March 2005, 12:44 AM   #2
speaker is offline speaker  United States
speaker's Avatar
Default Re: Audio schematics for GU50 ????
Thank's.
Certainly one of the more interesting, mechanical-aspect, tubes out there. Certainly someone, somewhere has built with them and commented; anyone?
speaker
Old 1st March 2005, 08:31 AM   #3
sajti is offline sajti  Hungary
The GU50 gives nice 60W in class AB with 650V plate, and 300V screen, with same plate to plate resistance as the 807.
sajti
Old 3rd March 2005, 10:24 AM   #4
wkopacz is offline wkopacz  Poland
Default GU50 (rus. √”-50) amps
use google and search for GU50 or √”-50 amp
example: JOGIS
and more...
regards,wk.
Old 3rd March 2005, 10:41 AM   #5
Post and so on...
sorry, but russian letters.....
JOGIS
Regards,wk.
Old 3rd March 2005, 11:57 AM   #6
It looks nice. I will put up some schematics next week. I have schematics for SE amp, and for PP amp with GU50.
sajti
Old 4th July 2005, 10:53 PM   #7
beamnet is offline beamnet  Netherlands
beamnet's Avatar
Send a message via MSN to beamnet
this is my go at a gu50 push pull
it is a modded kt88 schematic
sounds cool, but it's my first amp and have no reference...
Old 25th January 2006, 10:15 PM   #8
beamnet's Avatar
well, that was some time ago i posted.
For short, these ubes ROCK
the power they supply seems endless.
I have 150 watt rated speakers, and they buckle earlier than my pp 75watt amp!
Bas
Old 25th January 2006, 10:53 PM   #9
Tweeker is offline Tweeker  United States
Datasheet.
40 watts plate dissipation. 250V and 5 watts dissipation limits on grid 2.
Be sure your foil hat has a good low impedance ground.
Old 26th January 2006, 01:54 AM   #10
beamnet's Avatar
and these
Gu50 output problems beamnet Tubes / Valves 31 27th April 2013 06:53 PM
Gu50 cristelu2006 Tubes / Valves 13 18th November 2009 11:29 PM
Gu50 Set ? pwan Tubes / Valves 3 22nd April 2007 05:15 PM
Copyright ©1999-2017 diyAudio
