7241 tube - diyAudio
Old 22nd February 2005, 11:36 AM   #1
gianis is offline gianis  Greece
Default 7241 tube
I found some of these tubes : [ 7241 tung-sol] , I want informations , data, etc, abaut these. thanks
Old 22nd February 2005, 11:40 AM   #2
Send a message via AIM to martinab2 Send a message via MSN to martinab2 Send a message via Yahoo to martinab2
Information here
Old 22nd February 2005, 11:42 AM   #3
audiousername's Avatar
Horrible, horrible, horrible things.
Only capable of passing 1200mA, and 100W anode dissipation at 67 ohms ra. Horrible for OTLs.
You MUST send them to me for safe disposal, or even better send me some 7242s if you have any
Seriously, though, if you have enough, you could probably make quite a nice OTL. Datasheet here.
Jason
Old 22nd February 2005, 12:03 PM   #4
Default 7241 tube
I have 9 of them [ from old military stock] are these tubes good for SE topology?? I have no expiriance with OTL amplifiers. Thanks
Old 22nd February 2005, 12:14 PM   #5
Because of the valve's characteristics, you'll need a low turns ratio transformer capable of handling quite a large DC current, but yes, they will work for SE amplifiers. With the large Pa rating, I would imagine quite a lot of power would be available - probably >20W, but you'll have to keep an eye on the bulb temperature (not literally, of course )
Jason
Old 22nd February 2005, 12:19 PM   #6
I probably should add that the high input capacitance (I can't find a value for this, but it's going to be pretty large), and low m will make the output stage a devil to drive, but it's nothing that can't be overcome
Jason
Old 22nd February 2005, 01:06 PM   #7
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
Default Excellent tube!
Geiasoy Gianni!
What a wonderfull tube this is! I never imagined you could find such tubes locally! Anyway such a tube is supernice for OTL as proposed allready but also can be used in SE. It would be very interesting to try wind your own transformer as the primary resistance is too low thus too easy to make! I am sure its going to be very hard to drive such beast, but as already stated, nothing is impossible.
If you like any help you can call me at 6977744232
Panos
Old 22nd February 2005, 08:20 PM   #8
Default 7241
Thanks for the responses,, i`ll try to build something with these tubes [ i hope so] its difficult but i`ll try it..Thanks, Gianis
Old 23rd February 2005, 04:23 AM   #9
jlsem is offline jlsem  United States
jlsem's Avatar
A 500 ohm output transformer that can handle 400 ma. standing DC current is an awful lot of work for 18 watts.
CAUTION: Don't be misled by other parties on this forum. All tubes designated for proper disposal are to be referred to me first.
John
Old 23rd February 2005, 04:28 AM   #10
Agreed that the OPT will be a lot of work, and perhaps I should add that current sharing between the three cathodes within the envelope might be a concern - so individual cathode resistors would be preferable if cathode bias is used.
But not agreed that valves should be referred to John before proper disposal!
Jason
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
7241 tubes gianis33 Swap Meet 0 3rd July 2005 12:32 PM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Copyright 1999-2017 diyAudio
