Effect of cross-coupled "local" FB on plate load of previous stage - Page 3 - diyAudio
Old 15th April 2005, 09:33 AM   #21
diyAudio Moderator Emeritus
ray_moth's Avatar
My only remaining problem with his circuit, now that I understand it better, is the low level of bias on the first stage. I measured only 0.5 v between each 6SL7 cathode and ground. This would not allow a big enough input signal, as I understand it.
Old 15th April 2005, 02:52 PM   #22
Previously: Kuei Yang Wang
Konnichiwa,
Remember, there is local feedback and a negative supply....
Sayonara
PS, trust me, this circuit works as drawn and very well indeed.
Old 27th April 2005, 07:45 AM   #23
ray_moth's Avatar
I'm sorry, I don't see how that helps ... unless you're implying that the unbypassed individual resistors in the 6SL7 cathodes allow the cathode potential to "follow" the grid potential, thereby "opening up" the bias, so as to make it effectively much greater than it appears to be? Or does the "long tail" do that anyway? (I'm rather uncertain about this, I must admit.)
Old 27th April 2005, 08:55 AM   #24
Konnichiwa,
Consider the cathode resistors to the negative supply as imperfect current sources. Consider the cathode coupled through a modertae value resistor value (1...2K in my case). Now consider what happens if the respective valve starts to conduct (both balanced and SE Drive).
Sayonara
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 10:50 PM
Seeking advice on "Circlotron" cross-coupled feedback OTL design arteitle Tubes / Valves 8 5th March 2010 09:55 PM
Plate load for 6SN7 gain stage? G Tubes / Valves 53 16th July 2003 10:07 AM
Copyright 1999-2017 diyAudio
