Problem with my Darling! - Page 6 - diyAudio
Old 27th February 2005, 08:12 PM   #51
philipbarrett's Avatar
Send a message via AIM to philipbarrett
OK - the 10 cent Akai transformer worked!! Came directly out of my CD into an old pair of NAD speakers and it played at a moderate volume and sounded pretty good!
Now the speakers are 4 ohm but that's all the specs I have, being a sealed box I suspect that they are not very efficient.
That leads us back to the Hammonds, before I pull them let me check (very stupid question approaching) that i really did hook them up correctly. The B+/1626 Plate connects to the BRN/BLU primary wires, the 8 ohm speakers connect to the BLK/YEL secondry wires.
I had to ask.
Old 27th February 2005, 08:28 PM   #52
noisenyc's Avatar
blue=B+
brn=plate
blk=grd
yel=speaker+
are sure you have then phased the same?
try one at a time....maybe one is shorted...or wired backwards
-blackie.
Old 27th February 2005, 08:28 PM   #53
If it's in anyway meaningful I'm reading 102.1 ohms on the BRN/BLU primary & 1.7 ohms on the BLK/YEL secondary
Old 27th February 2005, 09:34 PM   #54
Found the problem - the banana jacks were shorting the Hammond outputs! Hahaha, who'd have thunkit?
I want to sincerely thank all you guys for the incredible help you selflessly gave in helping to tech this problem out. As I said in an earlier post, boy did I learn a lot from y'all.
Sounds pretty D-good too!
Old 27th February 2005, 09:40 PM   #55
noisenyc's Avatar
aHA!
must isolate jacks from chassis!
-blackie.
Old 27th February 2005, 11:38 PM   #56
OK here she is, I know, I shouldn't have skipped the metalwork class!
Old 7th March 2005, 10:09 AM   #57
your first project? congrats!
If I were you i would stick those trans underneath the chasis, not on top.
Apart from safety issues, they look ugly naked...
Old 7th March 2005, 03:54 PM   #58
Your amp looks quite nice. Any chance we might get a dark shot to see the tubes a' glowing?
I've been looking at this project for a first tube amp as well... Although I'd rather do the parallel version for a little more power. How easy/hard was it to build? Do the 125ESE's actually sound pretty good? A lot of people put down the cheap iron... How's the bass? Highs? Mids?
Old 7th March 2005, 04:59 PM   #59
I am really happy with the sound (& the 125ESEs) though at this point have only listened through a pair of cheapo speakers. I am particularly impressed with the stereo imaging, it really is tight. The mids & highs are very crisp & the transients are strong, it may be a little bass shy but it's hard to judge with the current set up. Certainly the bass that's there is tight & defined.
I think it's a great first build, as for the power I really don't think there's much in it. A subjective doubling of acoustic output requires a 10x power factor so you would have to build at least a 5 watt variant to really notice much difference. I am certainly experiencing no problems with speakers I suspect to be in the high 80's at best.
I am embarking on a pair of TL loaded Fostex's & will report back.
Best of luck.
Philip
A Darling.......ton Story .... east electronics Solid State 19 12th November 2011 12:12 PM
Darling 1626 amp rca9449 Tubes / Valves 9 7th October 2008 06:33 PM
which project for a darling amp kalinowski Full Range 4 28th May 2008 09:30 PM
Darling in Europe... (110 vs. 220) opopanax666 Tubes / Valves 12 31st March 2008 08:26 AM
Darling monoblocks Greyskale Tubes / Valves 3 14th March 2008 12:25 AM
Copyright 1999-2017 diyAudio
