Problem with my Darling! - Page 3 - diyAudio
Old 25th February 2005, 12:24 PM   #21
jeff mai's Avatar
Originally posted by philipbarrett
The coupling caps would be the 27uF films connecting the 6J4 plate to the 1626 grid I assume?
Yes those are the coupling caps, but I hope the value was a typo. 27uf is probably 100 times too big! It could also play havoc with clipping input signals because grid current would want to charge the cap.
Maybe try a smaller cap (much smaller - like less than 0.5uf - I'd shoot for 0.1uf) *and* testing with a smaller signal.
Old 25th February 2005, 12:27 PM   #22
Uh-OH, Philip,
those should be 0.22 uF, not 27 uF.
That is not likely your problem, but it *could* be depending upon the leakage of the large caps you chose, esp. if they're electrolytic.
Cheers/Fader
Old 25th February 2005, 12:42 PM   #23
philipbarrett's Avatar
Send a message via AIM to philipbarrett
sorry 0.27uF, it's early! Now those have ".27K" printed on them, that is correct?
P
Old 25th February 2005, 01:16 PM   #24
yup!!!
Old 25th February 2005, 01:24 PM   #25
noisenyc's Avatar
hey phil
this might sound silly but...it happenns. check all your output wiring, esp the tube pinouts.
double check ground path as well.
-blackie.
Old 25th February 2005, 01:30 PM   #26
My Darling
DiyTao
Old 25th February 2005, 02:14 PM   #27
MelB is offline MelB  Canada
Philip, have you checked the value of the grid resistor on the 1626's?
Old 25th February 2005, 02:23 PM   #28
Been through the whole thing with 3 fine tooth combs! Then I got a technician friend (who builds balls-to-the-walls tube guitar amps) to go through it with a 4th! He has all the test gear, dual-trace scopes & the like. Gotta suspect the tubes here at this point.
The up-side of all this is that I've learned a lot. If I'd plugged the thing in & it had worked first time I'd have been thrilled but I wouldn't have got the tube trouble shooting experience. I've had to pore over data sheets, brush up my basic electrical theory, figure out how to test various areas, so it's really been a positive experience.
P
Old 25th February 2005, 02:53 PM   #29
noisenyc's Avatar
good point...grid leak resistors...also what kind of OT iron?
-blackie.
Old 25th February 2005, 02:57 PM   #30
Hammond 125 ESE's, all hooked up correctly (believe me I checked) :-)
A Darling.......ton Story .... east electronics Solid State 19 12th November 2011 11:12 AM
Darling 1626 amp rca9449 Tubes / Valves 9 7th October 2008 05:33 PM
which project for a darling amp kalinowski Full Range 4 28th May 2008 08:30 PM
Darling in Europe... (110 vs. 220) opopanax666 Tubes / Valves 12 31st March 2008 07:26 AM
Darling monoblocks Greyskale Tubes / Valves 3 13th March 2008 11:25 PM
Copyright 1999-2017 diyAudio
