Problem with my Darling! - Page 2 - diyAudio
Old 23rd February 2005, 08:12 AM   #11
Yes, Philip, something is very badly out of whack here. If you put 1vAC into the 6j4, you ought to have less than 55 vAC out. With .088vAC in, you'd get less than 6.8vAC out. It is *impossible* to actuall get readings such as you have, no matter how many times you check them.
Let's solve that problem first; you have something wrong with your test setup.
How do you know that the source is putting out a sine wave? What are you using to check the voltages and what scale are you using for each reading (only* on the 6J4? Also, tell us again what the reading is at the cathode of the 6J4 (I'm in the reply screen and can't see the main thread).
You would have a far better chance of working this out if you could find some way to get a good sine wave at 1vAC into the grid of the 6J4. Do you have a friend with a real signal generator?
Don't even think about the output stage at this time.
Cheers/Fader
Old 23rd February 2005, 01:31 PM   #12
philipbarrett's Avatar
Send a message via AIM to philipbarrett
John - thanks for your help.
I think the input math is correct, my iPod is delivering 880mV (not 88mV) which by your math of 1V in = 55V out makes my reading of 34V out about right?
I am measuring with the Radio Shack RMS multimeter in "auto" and have the Spectra-Foo FFT analyzer running on my Mac to confirm the sine wave.
The cathodes on the 6J4s read 2.7VDC each.
I am trying to get time on a scope & generator today and will hit the input with 1VAC.
Thanks again.
Philip
Old 23rd February 2005, 01:54 PM   #13
OK, Philip,
That last sounds all good. You don't need to sue a signal generator now that we've determned that you've got nearly a volt and that the sine wave is good. Better (moe convenient) test gear is nice, but now necessary if you've got *something* that yoiu can trust.
So, you've got 34vAC out of the 6J4, so that's all good. Bias sounds good, and so did plate when we were looking at that.
Now for the output: Bias sounds good as toes grid drive. E can't remember plate, but I think that was good. So, was the 10V or so output you mentioned initially the AC riding on the plate voltage? Or was it the voltage at the 8 Ohm speaker terminals? I suspect that it was the former. If so, and your tubes are good, we have a serious problem.
Try this: With the signal applied to the input, put your RS DVM on the AC scale that suits the grid and tell it to do relative (dang, too bad that DVM dosn't have a dB scale!!!). Now move to the plate and report the relative reading, + or -.
Though I don't believe that two 1626s would have gone bad in exactly the same way and value, we can't dismiss the possibility. Get another one, AAMOF get a pair, as you'll need them when you build your Parallel Darling :-)
Let's see if the new ones are "similarly failed" ;-)
Cheers/Fader
clutching at straws :-)
Old 23rd February 2005, 07:24 PM   #14
OK - did a full bench test today using 1KHz at 1 V as a test source. All is fine until we reach the plates of the 1626s. At that point the gain disapears and the signal is heavily clipped. We took some current readings, measuring the Plate at 23mA at idle, 37mA with signal applied and the Cathode at 18mA under idle. This seems high, plus the 500R/5W resistor is getting pretty hot.
My friend with the test gear is also suspecting the tubes so I will take your advice & order another pair & see what happens.
In the meantime I might start my phono pre-amp, any suggestions?
Thanks, your time is really appreciated.
Philip
Old 23rd February 2005, 08:52 PM   #15
jeff mai's Avatar
Something to check - is the 1626 grid at 0VDC with no input signal? I'm thinking maybe leaky coupling caps could cause the problem. Maybe not but worth a look. I'd also measure the cold value of your cathode R just to make certain it hasn't gone weird.
Although this probably isn't the problem, 880 mVrms input will try to drive the grids of the 1626 well positive relative to the cathode at your bias point. This will do weird things to the operation - bias voltage and current will shift, grid current will start - not good. If you want to ensure "normal" operation while testing, 250 mVrms input is more appropriate.
Old 23rd February 2005, 08:56 PM   #16
Dang, Philip,
I just spent 10 0minutes talking about phono and line stages and i hit some wrong key and it all went into the bit bin somewhere.
I'll simplify a good bit here:
Do you plan to scratch-build or buy kits?
Do you plan to build a line stage?
I have strong opinions on both these items, and will go on if you wish :-)
Cheers/Fader
Old 23rd February 2005, 09:46 PM   #17
Actually, I started a new thread since this is moving OT, but anyway;
1) scratch build
2) yes, I will build a line stage but the plan is to initially drive my Darling (assuming she'll ever work) with the RIAA pre and then at least I'll be listening to vinyl through my (yet to be built) Fostex based speakers.
The whole plan is to have built as much of a complete system as possible with my own fair hands! I'll leave the CD transport & DAC for later, likewise the turntable but hey it's a start.
P
Old 23rd February 2005, 10:19 PM   #18
Tood Show, Philip,
I'll nove this over to the other thread, but will stand by on the Darling thread to await news and to offer help.
Cheers/Fader
Old 25th February 2005, 05:28 AM   #19
Philip,
I just thought abut grid current and signed on to suggest coupling caps. Readingabove, I'll just second jeff's suggestions.
Old 25th February 2005, 12:12 PM   #20
Thanks guys! I'm waiting on some new tubes too. The coupling caps would be the 27uF films connecting the 6J4 plate to the 1626 grid I assume?
Philip
A Darling.......ton Story .... east electronics Solid State 19 12th November 2011 11:12 AM
Darling 1626 amp rca9449 Tubes / Valves 9 7th October 2008 05:33 PM
which project for a darling amp kalinowski Full Range 4 28th May 2008 08:30 PM
Darling in Europe... (110 vs. 220) opopanax666 Tubes / Valves 12 31st March 2008 07:26 AM
Darling monoblocks Greyskale Tubes / Valves 3 13th March 2008 11:25 PM
Copyright 1999-2017 diyAudio
