diyAudio Sponsor
Old 19th February 2005, 09:55 PM   #1
zxx123 is offline zxx123  United States
Default Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement?
I found a strange part from garage. It says that it is an tube rectifier replacement for tube socket.
I tried in my SE amp. It worked, but B+ was higher than tube rectifier. It seems to be a kind bridge diode.
Anybody heard about this brand and part?
Old 19th February 2005, 10:28 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Hm, quite a few hits on Google, though no datasheets yet. Looks to be a replacement for 5U4/5Y3/etc. (any rectifier with that base), rated 1600PIV 0.75A (probably total DC output, not per diode; two series pairs of 1N4007s would be rated 2kV, 2A the same way).
Depending on how old it is, it might be worth something. Or just a piece of junk. *shrug*
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 19th February 2005, 10:35 PM   #3
Sakes/Tarzain is a name out of my youth. I can remember when they introduced 500 mA. Silicon diodes that mounted in 3AG fuse holders.
That device is "2" diodes mounted on an Octal socket with a covering can. That the B+ is somewhat higher is to be expected, as PN diodes have a MUCH lower forward voltage drop than vacuum diodes do. Expect a considerable amount of switching noise from those old diodes. If your amp's PSU has a choke in its filter, the noise is removed from the B+. In any event, switching noise could get into the signal path via filament windings on the power trafo.
If you like, run a Google search against 1N????, as that's the part number.
Eli D.
Old 20th February 2005, 02:21 AM   #4
jlsem is offline jlsem  United States
jlsem's Avatar
I believe the Tarzian units have a voltage dropping resistor inside as well. They generally have part numbers as drop-in replacements for a variety of tube rectifiers. I have seen many of these used in FAA euipment where application is critical.
John
Old 21st February 2005, 05:02 AM   #5
Default Thanks..
I found spec. paper in another box.
They say same as both of you explained to me.
Thanks.
tube rectifier plug in s-s replacement pforeman Tubes / Valves 5 3rd June 2009 12:50 AM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 09:26 PM
silicon or tube rectifier? felixx Tubes / Valves 5 4th October 2006 02:43 PM
Dynaco rectifier replacement? Original Burnedfingers Tubes / Valves 10 20th September 2005 03:24 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 03:43 PM
Page generated in 0.09521 seconds (72.63% PHP - 27.37% MySQL) with 11 queries
