Old 16th February 2005, 06:33 AM   #1
Default Plate curves or Op Point for 6KN8?
Hi all,
I have seached fruitlessly all over the web and cannot seem to find much information other than basic summary data for this valve. There have been a few cryptic (generally positive) postings on this forum which imply that some here have used this tube, so I'm crossing my fingers that a memeber may have some data on the plate curves or a suggessted operating point.
The 6KN8 looks to be a really promising device with a mu in the 40's and Rp around 2k.
Thanks in advance for your help.
Bill
Old 16th February 2005, 06:41 AM   #2
audiousername's Avatar
NJ7P says that 6BS8 is a substitute. Sorry, haven't found anything on the 6KN8, not even in the Vademecum...
Jason
Old 17th February 2005, 07:17 AM   #3
Default Thank you for the link.....
it may be as good as I get to get started anyway.
The 6KN8 looks a bit like two of the Russian 6C4Pi (not 6C45Pi)tubes in the same bottle which is why it had some attaction.
Bill
Old 17th February 2005, 11:44 AM   #4
SY's Avatar
I've been using it in various apps over the years; it's a high mu version of the ECC88 family, sourced from Japan. It's happy at 8-10mA of plate current, works great in preamps. No curves, alas; even Frank's page is stumped.
If there's a sucker born every minute, where do the rest of them come from?
Old 18th February 2005, 06:44 AM   #5
Default Thank you I'll give it a try (nt)
nt
Old 11th June 2011, 04:59 AM   #6
Tony is offline Tony  Philippines
Tony's Avatar
Hi Sy,
having a higher mu, would you say the 6KN8 is even better in the role of a cathode follower?
i am thinking of implementing a version of your Impasse preamp using 6H23, driving a 4KN8 concertina for a balanced output...
as i do not need the higher output swing, can i use a lower b+ so that i can use those 250 volt caps i have in plenty?
6JN6 screen-drive (g2 driven) plate curves? GordonW Tubes / Valves 26 23rd April 2008 01:56 PM
15E and plate curves lochness Tubes / Valves 5 4th November 2007 03:41 AM
basic question on plate curves Craig405 Tubes / Valves 14 27th October 2006 08:56 PM
please explain plate curves frank2395 Tubes / Valves 4 19th May 2005 12:03 AM
plate characteristic curves help jlsem Tubes / Valves 1 15th July 2003 07:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
