#2 |
Get a more substantial driver stage. A 6J5 running at a meagre 3.8mA of current is a bit wimpy for driving a big valve (and input capacitance). You might think about ditching the global feedback as well.
Jason |
#3 | |
Hi, Jason I'm very new on tube amp, can you give me some idea on the driver stage?? |
#4 | |
Jason |
#5 |
The 6C33C is not that power hungry as it seems, the input capacitance is ~150pF and grid current is more or less non existent, (100k is no problem as a grid leak), therefore a 6J5 is quite enough for driving a 6C33C, (you get a -3dB cutoff at >100kHz). However it is quite often so that cathode followers or in some cases SRPP's are used to drive the 6C33C. Some years ago I bought a kit amplifier from San-ei in Japan designed by Dakesue, (he was the first one to use 6C33C outside USSR). In this amplifier a cathode follower is used, DC coupled to the grid of the 6C33C, it works very well, see here http://www.tubetvr.com/se.html What is the specification of output transformer? impedance ratio? specified DC current, primary inductance? if you have weak bass I would suspect the transformer first. Regards Hans |
#6 | |
I don´t have any experiences of my own when it comes to 6C33, but a friend of mine had quite a bit of trouble to get full HF bandwith out of his 6C33 SE amp. His resistor loaded 6SN7 driver didn´t manage, so he ended up with a CCS loaded EL82 (trioded) driver. |
#7 | |
Do you know more details about the circuit and measurement values? Regards Hans |
#8 |
tubetvr:
For more specific details, ask user Lord at hififorum.nu |
| 6c33c-b & 6c33c-v | skybird | Tubes / Valves | 4 | 21st April 2009 06:21 AM |
| 6C33C-EB / 6C33C-EV extended life ? | ger56 | Tubes / Valves | 2 | 14th October 2007 05:54 PM |
| WTB 6c33c-b | woody | Swap Meet | 0 | 20th September 2005 07:36 PM |
| WTB 6c33c-b | woody | Swap Meet | 0 | 8th September 2005 02:41 PM |
| 6c33c-b Se | morfeas | Tubes / Valves | 3 | 19th November 2004 11:55 AM |
