OTL ECC88 amp - diyAudio
Old 12th February 2005, 06:14 AM   #1
Tyimo is offline Tyimo  Hungary
Default OTL ECC88 amp
Hi!
I find this simple OTL amp schematic, but I don't know should I trust it or not?
The author says that it is capable to drive a 15 Ohm speaker with 1-2 W ?!? Basicaly it is a headphone amp, but could be used also for sensitive speakers.The first tube could drive even more output tubes ( 10 ) and so could give more power.
Is it realy true?
Is the circuirt realy working?
Has somebody a very simple, but good OTL plan for an OTL beginer like me?
Tyimo
Old 12th February 2005, 07:05 AM   #2
Hi Tyimo,
To get 1W in 15 ohm you need to supply an RMS current of SQR(1/15) = 0.26A and a peak current of .36A and that is the mimimum cathode current in idle for the circuit in the attachement as it goes in class A, (in reality you need an even higher current to avoid unlinearities). There are 4 tubes so each tube need a curent of 90mA. To get 90mA cathode current at 0V at the grid you need a anode voltage of ~180V so the dissipation in each tube will be ~16W
The ECC88 is specified to max cathode current 25mA and max dissipation of 1.8W.
The cathode resistors value in the circuit look very high and can not be right, with 6.8k the cathode current will be very low, could it be that it should be 6.8ohm? also the anode resistor of 100ohm will limit the max current.
To answer your questions no, its not true, it cant give 1W even at 15ohm and it is not possible to build a 1W 15ohm amplifier with 4 ECC88 triodes, (they will probably melt). Also the circuit diagram is incorrect even for a headphone amp as some of the resistor values are wrong.
Regards Hans
Old 12th February 2005, 10:03 AM   #3
frugal-phile(tm)
planet10's Avatar
Are you sure the ECC88 isn't just the driver tube?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th February 2005, 10:22 AM   #4
It doesn`t help, with the anode and cathode resistor values shown it is impossible to get enough current to get any noticeable amount of power from this circuit.
Regards Hans
Old 13th February 2005, 06:48 AM   #5
Hi Hans!
Thanks again, because last year You already answered me the same in e-mail!
I believed you, but I wanted to know is it posibble to modify-repair this circuit to working.
Do you know something very simple OTL to try? ca: 4-6 W on 16 Ohm?
(I didn't finished your great design OTL amp yet, because it is very hard to get the 6C33C tubes here)
Thanks again
Old 13th February 2005, 07:41 AM   #6
Hi Tyimo,
The "only" problem with building an OTL is to make a circuit that can supply high enough current and doesn`t burn up. To make a class A OTL is much more difficult than class AB and that is why as far as I know there are only one low power class A OTL on the market and all others are class AB1 or even AB2.
An example: if we have a tube that can withstand a continous current of 0.5A we can build an class A OTL that can give 1W in 8 ohm, that is not very much, (the output power will be Ipk^2*Rl/2 or 0.5A^2*8/2 = 1W, in this circuit the peak current can never be higher than 0.5A)
If we use the same tubes in a class AB type amplifier we can assume that the tube withstand an average current of 0.5A but a higher instantanteous peak current and then the max output power will be higher. With 0.5A average current the RMS current is 1.1 higher or .55A and if we use 2 tubes the RMS current in the speaker can be allowed to be 2 times higher or 1.1A, this gives output power of 1.1^2*8 = 9.7W. The no signal current trough the tubes should be chosen at a reasonable value to minimise distortion and idle dissipation.
The simplest OTL circuit is probably the one that Philips had as example in their data sheet of EL86, it goes in class A and use only 2 tubes, see here http://www.tubetvr.com/otl.html I built this as my first OTL but with other tubes and got ~0.2W which was enough to get me interested in OTL`s. Using EL509 and 0.5A idle current this circuit can give ~1W with good reliability. For higher power class AB is the only way to go and then there are many circuits to chose from.
Regards Hans
Old 13th February 2005, 07:52 AM   #7
diyAudio Moderator Emeritus
jean-paul's Avatar
Default A working schematic with ECC88s as power tubes....
.... but with an output transformer.
This amp was once published at the audiopages of Klaus Boehm ( website is down now ) with several other interesting projects. Klaus was the designer of a non oversampling TDA1541A DAC as well which inspired Thorsten to design the Adagio DAC. In other words, the published projects all worked and were thoroughly tested.
http://www.geocities.com/freespeedpro/1W-se.jpg
You must goto http://www.geocities.com/freespeedpro/ first and then change the address bar to http://www.geocities.com/freespeedpro/1W-se.jpg
http://www.diyaudio.com/forums/showthread/t-3273.html
It's only audio. Member of the non modular PCB design committee
Old 13th February 2005, 08:43 AM   #8
Yes, the circuits look very similar except for that the one Tyimo showed is supposed to be OTL which the one you show is not. To get 1W from 4 ECC88 using an output transformer shouldn`t be any problem at all but quite impossible as OTL and normal speaker impedances.
The circuits are in fact very similar, so similar so I believe the non functioning OTL is based on the transformer coupled variant.
Regards Hans
Old 13th February 2005, 09:06 AM   #9
jean-paul's Avatar
My thoughts as well.
You are right of course about it being non-OTL. I guessed the emphasis was on a working power amp with ECC88 as power tube rather than it being OTL ( which it was not ). I edited my post according your comment.
Old 14th February 2005, 04:32 PM   #10
Hans: Thanks a lot!
Greets:
Tyimo
ECC88 Help rhysh Tubes / Valves 2 1st December 2008 10:52 PM
ECC88 vs 6SN7 kacernator Tubes / Valves 13 17th March 2008 09:55 PM
ECC88 at 12 volts Pano Tubes / Valves 26 7th November 2005 05:37 AM
Which Amperex ECC88 is the best? ac2005 Tubes / Valves 1 7th September 2005 03:04 PM
What to do with ECC88's? Simpleton Tubes / Valves 15 16th June 2005 08:39 AM
Copyright 1999-2017 diyAudio
