| diyAudio Sponsor | ||
#21 |
If you have a very low source impedance and you use very few turns you can quite easily wind your own with good results, be it an autoformer or a true transformer (place the tapped secondary between two layers of 1/2 primary each), however the nominal impedance will be low, usually in the region of a few 100 Ohm and level handeling tends to be shitty.
Hi Kuei This point is very pertinant to a project that I am working on right now. I was under the impression that generally speaking transformers work better in a high current / low impedance environment. I this light I was thinking that if the o/p impedance and the termination impedances are both lowish then fewer turns can be used without loss of low level quality given that the magnetic flux in the core for a given i/p signal is equal to that of a higher impedance system with more turns. Am I mistaken ? or is this understanding sound ? thanks mike |
#22 | ||
Previously: Kuei Yang Wang
Konnichiwa,
Sayonara |
#23 |
Some more out-loud thinking on TVC triamping:
Another benefit of the relaxed bandwidth requirements might be reduced low-level distortion through use of air gaps while still maintaining sufficiently high inductance. As I understand it, TVCs without air gaps can allow a little bit of low-signal distortion to creep in (the bottom of the S-shaped initial-magnetization curve). But of course, gapping lowers inductance. I don't know for sure, but I imagine it wouldn't be a terrible challenge to wind a bass TVC with bandwidth to >5kHz, inductance around 100H, and a gapped core. The mid TVC wouldn't need more than 10-15H, and I doubt the treble would need as much as 3H, so again, gapped cores all around. Perhaps even a ferrite core on the treble? |
#24 | |||
Konnichiwa,
Sayonara |
#25 |
I believe I will try it. Thanks for the encouragment. Gapped silicon steel cores for bass and mid should be far less expensive than mumetal, and ferrite cores are a dime a dozen. I'd like to get the whole six-channel volume control done for $400 or less. (The most expensive part may end up being the 6-deck switch.)
Do you think split windings on UI humbucker cores would be worthwhile? Shielding might then be far less of an issue. |
#26 | ||
Konnichiwa,
Sayonara |
#27 |
I always wanted to try one of these units before spending big bucks a proper TVC. Granted some models don't do 20-20KHz but a few do.
www.hometech.com/audio/volume.html But, I ended-up skipping this step and order Tx-102s if only I could find a nice chassis to put them in I would get started. Seems hard to find a metal box with wood sides. All wood, or metal sides with wood top. I would prefer avoiding to build the chassis as my tools and skills are more electrical than wood working or metal working. cheers paba |
#28 | |
It also seems to me that, in transformers of equal inductance, ungapped vs. gapped steel cores might sound quite different. In one, the initial magnetization curve of the steel predominates. In the other, the characteristics of the air in the gap. Any info or experiences on this? On an only semi-related point, I wonder what sonic changes might be had by including a small coil to carry a little DC current to effectively bias the core into its linear region. Obviously, the design would have to account for the reduction in available inductance. I imagine it wouldn't benefit the bass, but maybe higher frequencies... |
#29 | ||
Konnichiwa,
Sayonara |
#30 | |
Fact is, -3db @ 500Hz for the treble section is probably overkill since I'd rarely cross below 4k. If I raise the cutoff to 1khz, that'll need half the inductance. Think it's really possible with an air core? |
| transformer volume control (TVC) | louie 3 | Solid State | 22 | 4th October 2009 02:41 PM |
| Transformer volume control questions. | gsd | Tubes / Valves | 18 | 4th March 2009 02:33 PM |
| Transformer Volume Control | Sandor | Parts | 7 | 1st October 2008 09:51 PM |
| FS: Bent Audio TX102 MKIII Transformer Volume Control | Firebottle | Swap Meet | 2 | 26th January 2005 11:32 PM |
| Transformer-based volume control | wboyd | Analogue Source | 4 | 18th August 2004 04:57 PM |
| Page generated in 0.13155 seconds (84.48% PHP - 15.52% MySQL) with 10 queries |
