want to build SE450TL
Old 18th February 2005, 04:35 AM   #21
day is offline day  Thailand
wow!!! 6C4 p-pp look nice . if i need about 20watt how many tube can use. i aso have 50 of 6AQ5 but it si not triod.
Old 18th February 2005, 06:37 AM   #22
audiousername is offline audiousername  Australia
audiousername's Avatar
The 6AQ5 is probably more sutable for the output stage of audio amplifiers than the 6C4 - even if it isn't a triode, you can try triode-strapping it, or apply a large amount of local feedback around the output stage such that the problems with pentode-mode operation are greatly reduced.
Just for reference, some links to datasheets on Franks: 6C4, 6AQ5.
The number of valves you'll need for 20W will depend on whether they're run class A or class AB. But you have plenty, so it shouldn't be so much of a problem
Jason
Old 18th February 2005, 07:40 AM   #23
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The 6AQ5 was the small bottle version of the 6V6. Quite similar to EL84/6BQ5 and except for some changes to the cathode R pretty much interchangeable. Lots & lots of stuff out there to look at to apply them to an amp.
Make a nice 1.5-2 W SE amp in triode, 4-5 W SE in pentode (search on the forum for RH84), 4 W in PP Clas A, 12-15 in AB PP.... and you could parallel for more power (althou likely at a sacrifice of coherency).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
want to build SE450TLHide this!Advertise here!
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
build or buy navin Multi-Way 9 16th November 2004 05:36 AM
Looking to build a sub. jaybird Multi-Way 6 14th May 2003 01:52 AM
Copyright ©1999-2017 diyAudio
