want to build SE450TL
Old 15th February 2005, 01:50 AM   #11
day is offline day  Thailand
no! ti is 300b .. i love triod. i think tetrodes is not goog as triod
what do you think
sorry for bad ENG.
thank you.
Old 15th February 2005, 05:42 AM   #12
audiousername is offline audiousername  Australia
audiousername's Avatar
No need to apologise for your English, it's much better than my Thai
Pentodes and tetrodes can be very good, it's just that they tend to produce too much distortion and have too high an output impedance on their own - so they need some negative feedback to work well (preferably of the local kind). In any case, some tetrodes can make very nice triodes.
Jason
Old 17th February 2005, 05:41 AM   #13
this is my RCA8121 it look nice . today i saw new tube 6C4 . IT can be preamplier and how dose it sound.
thak you
Old 17th February 2005, 05:49 AM   #14
rca 6C4
Old 17th February 2005, 07:20 AM   #15
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Isn't the 6C4 essentially half od a 12AU7/ECC82?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th February 2005, 08:52 AM   #16
Whoa! It looks like you have about seventy 6C4s there, and I can see some other valves which I can't quite make out in the box at the top left of the picture.
Dave is right - the 6C4 is essentially half a 12AU7/ECC82/etc...
Why not try making a massively paralleled amp - maybe something along the lines of the Tim's Hept'AU7 <- why isn't this link working?
Jason
Old 17th February 2005, 09:06 AM   #17
frugal-phile(tm)
planet10's Avatar
Hept'AU7
Hept'AU7
just testing
Old 17th February 2005, 09:10 AM   #18
frugal-phile(tm)
planet10's Avatar
The parser is choking on the ' in the URL -- not a legitimate character for a URL... i'm surprised the graphic worked. The working URL probably 404s since i took out the '
dave
Old 18th February 2005, 01:59 AM   #19
bear is offline bear
bear's Avatar
Default Re: want to build SE450TL
Originally posted by day
HI
I have 3 of 450TL. can i do SE amp? anybody have circuit
thank you
Sell to a licensed Amateur Radio Operator.
Ebay.
Or better still trade with a licensed Amateur Radio Operator
for some tubes that will fly much better in SE operation:
845
211
etc...
The voltages required are very high with the 450TL and the plate impedance is scary high too - makes for a tough xfmr match...
Not a project for someone who is not clear on the tube and working safely with LETHAL high voltages...
Makes a fine AM ham radio transmitter tube though!
_-_-bear
PS if you were in north america you'd have no trouble finding hams who want and use them class C... if they are good, don't waste them on lamps!
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 18th February 2005, 02:06 AM   #20
bear's Avatar
thak you
That is a 4CX250B
4 elements... 4CX----
CX = ceramic & metal
250watts of plate dissipation.
Useful for class C RF or Class AB modulator service.
Very high voltage ~2kv and up.
Not a very good audio tube, but usable in a stable circuit.
Eimac and RCA showed some applications as modulators.
High plate impedance makes it tough though.
FORCED AIR COOLING (noise)
NOT a preamplifier tube!!
Nice tube for RF, a pair will do ~1kW PEP as a linear - the tube is useful up into the VHF spectrum.
Again, sell or trade to a licensed ham radio operator!
_-_-bear
_-_-bear
want to build SE450TLHide this!Advertise here!
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
build or buy navin Multi-Way 9 16th November 2004 04:36 AM
Looking to build a sub. jaybird Multi-Way 6 14th May 2003 12:52 AM
Copyright ©1999-2017 diyAudio
