I plan to scratch build a pair of push pull monos based loosely on the Dynaco Mk III, each mono using either two EL 34s/6550s/ or KT 88s. Could anyone tell me what kind of output power one could expect with these options, assuming that the OPT can handle upto 60 watts?
Thanks in advance.
George
Thanks in advance.
George
Depends on a lot of things, especially the maximum allowable supply voltage, load impedance and acceptable distortion (especially of the nasty crossover type).
Philips gives data for a pair of EL34s in class B producing 100W. The KT88 may be able to produce somewhat more power.
You could easily meet or even exceed the OPT's 60W rating - but more power does not mean it will sound good.
Ditto what a-u-n said, but another factor to take into consideration is class of operation and the way the tube is connected. Class A will give you less than the 60W that the Mk3 will in AB1 UL; class A triode maybe 15 - 20W, etc.
If you have none of the components and are starting from scratch, work out how much power you want and work from there to find a configuration, PS voltage, OPT turns ratio etc that gets it for you. For example, if 15W will do it, then B+ = 400V, Ia = 85mA/tube and 7ka-a for the OPT gets you there (from memory) in Class A triode.
The tube manufacturer datasheets will often have example operating points for different configurations too.
