SE ultralinear amplifier generate a lot of Odd harmonics ?
Old 7th February 2005, 04:33 PM   #1
flyingman is offline flyingman  France
Default SE ultralinear amplifier generate a lot of Odd harmonics ?
Does anyone know if an SE ultralinear amplifier generate a lot of Odd harmonics compare to a triodes SE?
Does anyone know the Mr willis's amplifier ( SE 813) sound very well?
Thank.
Old 7th February 2005, 06:19 PM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Default Re: SE ultralinear amplifier generate a lot of Odd harmonics ?
Probably less (assuming you use a little global NFB to reduce Zo, as I recall Zo tends to be a bit high in UL). It might be higher in relation to the 2nd harmonic, but both will be much lower (perhaps 2% total compared to 5%).
Just guessing, I haven't built an UL amp yet.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 8th February 2005, 06:19 AM   #3
audiousername is offline audiousername  Australia
audiousername's Avatar
Have a look at the various UL curves here and do a bit of loadline analysis and you should have a fairly good idea.
I haven't built an UL amp either, but I think that distortion would likely be higher - the curves are less evenly spaced in UL when comparing with triode mode.
Jason
Old 8th February 2005, 10:02 AM   #4
Brett is offline Brett
Brett's Avatar
Thank.
In my experience, yes, more odd harmonics and the spectrum extends further. But it depends on the application.
I don't like UL's and wouldn't waste a good 813 on one.
SE ultralinear amplifier generate a lot of Odd harmonics ?Hide this!Advertise here!
WOO building things that generate stuff! tresch The Lounge 0 25th July 2009 11:21 PM
Whats the max voltage my cars electrical system will generate? MikeHunt79 Car Audio 11 15th January 2008 08:59 PM
Ways to generate clean electricity? jacquesl Everything Else 46 26th January 2007 09:48 PM
help to generate frequencies woodturner-fran Digital Source 6 8th May 2006 08:43 PM
A 10W ultralinear amplifier with unique features. Joel Tubes / Valves 81 8th July 2003 11:26 AM
