The T-Rex SET Amplifier DIY project
Old 27th August 2006, 08:56 PM   #61
VT67 is offline VT67  Belgium
VT67's Avatar
I'm also kinda interested in this project. For the last five years now I want to build me a 300B amp, got a lot of parts to do so but up til now I haven't deceided on which concept. I have two sets of 300B's, AVVT and Krone.
Old 28th August 2006, 01:15 PM   #62
kmtang is offline kmtang  Canada
kmtang's Avatar
Hi Peter,
Congratulations on your new born T-REX. That's something I want to build next.
Hi GeWa,
Suggest you to build Mono Blocs because it weighs less. The stereo one just way to heavy to flip over for service and modification.
Johnny
Old 17th October 2008, 05:09 AM   #63
sunrise is offline sunrise
sunrise's Avatar
Send a message via ICQ to sunrise
no more pic's????
when you burn it - burn it good
Old 19th April 2013, 07:24 PM   #64
IslandPink is offline IslandPink  United Kingdom
I recently finished building the shunt-regulated T-Rex power supply for my existing C3m/300B SE amp . I might as well mention it on this (old) thread, as I picked up this discussion on a search when checking comments on the circuit .
Here's my main thread -
audio-talk :: View topic - Future plan for 300B XLS amp
I did quite a bit of LT Spice analysis when deciding whether or not to build .
Starts here : ( long )
audio-talk :: View topic - Valve Shunt Regulator Design Walk-Through
Overall it's been well worth the effort . It definitely beats the Series-regulated supply I had before . This was a Verdier/Thorsten style circuit with 6080 pass tubes and EF86 error amp , but with a substantial cLC supply up-front . This in turn was better than the cLCLC passive supply I used to use pre-2008 .
The new TRex supply has slightly better midrange than the series-reg . It has signifcantly better bass tone and bass timing than the series-reg . The whole bottom-end now sounds more like Class A PP , although the fluid and natural SE tone is retained .
Spice sims confirm that most of the AC return current path is through the KT88 cathode by-pass cap : make sure if you build that you put in the best possible cap here - I've just changed to a combination of a 220uF Elna Cerafine, plus an Audyn 2.2uF/100 film-foil cap here . This seems to be the best so far .
Old 29th May 2016, 06:26 PM   #65
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Sjef View Post
A couple of months ago me and a couple of audio friends have compared all of our 300B diy amps in one setup. they where al driven by a transformer coupled 5842 preamp and where driving a pair of diy horn speakers. I don't know exactly all the schematics of the amps but there where four different topology's
1) 5687 srpp / 300B
2) d3A/ecc99 mu-stage, cap coupled, we connected, grid chokes, all Black Gate WKZ, Jupiter wax coupling caps etc amorfe core output stage and chokes (my own ones, total cost about 2500 euro))
3) the biggest one, somewhat similar to the T-rex with massive tube regulated power supplies and d3A/#27 tubes input stage, silver amorfe core output stage etc (total cost about 4000 euro)
4) A monkey style 6N1P/300B with very cheap Italian transformers (don't know the brand name) (total cost about 700 euro)
and (sadly for me) the cheapest amp sounded clearly the best of all, had the best micro detail, the best micro and macro dynamics, the biggest soundstage and more power than all the others. The circuit was based on a monkey style 6N1P / 300B combination.
Do we know what the key feature of the Monkey amp is that makes it the winner, is it dc coupling ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
The T-Rex SET Amplifier DIY projectHide this!Advertise here!
Amplifier Project gbowne1 Tubes / Valves 16 24th April 2008 10:55 PM
Pre-amplifier Project Help tumler Solid State 2 8th August 2007 10:15 PM
New Amplifier Project The Peasant Solid State 40 7th February 2005 11:15 AM
What is the best amplifier project...? Danyele82 Solid State 11 2nd May 2004 02:05 PM
My new amplifier project sajti Solid State 7 14th August 2003 02:15 PM
Copyright ©1999-2017 diyAudio
