| diyAudio Sponsor | ||
#81 |
make yourself a good DIY antenna. Or buy one. I know that the FM-Dynalab ones are excellent. The vertical ST-2 can be located in your attic or mounded outside at the peak of your roof. It is a 54" (1/2 λ antenna) with a transformer coil (or is it a choke?).
Yagi type of aerials are still out there. Many can be had from scrap, as lots of folks throw them out, after all, who uses an antenna for TV now? I'm sure there are DIY antenna posts here, so do a search You may al;so try something like this. Cheap, and easy to make, and much better than any of the simple dipole "T" types
stew ☮ -"A sane man in an insane world appears insane." Last edited by Nanook; 23rd September 2011 at 10:51 PM. Reason: added a link |
| Telefunken Consoles: not just for tube and iron scavenging! | pjanda1 | Tubes / Valves | 3 | 20th August 2008 09:40 PM |
| My friends in the USA - tube stores in LA | Rob11966 | Tubes / Valves | 3 | 4th August 2008 03:51 AM |
| Any tube stores in Burnaby, Vancouver, Canada? | qguy | Tubes / Valves | 2 | 12th July 2008 12:16 AM |
| tube stores in moscow | trancy | Tubes / Valves | 1 | 5th August 2005 12:14 PM |
| Thrift store find | Magnetmaz | Tubes / Valves | 37 | 13th August 2003 03:24 AM |
| Page generated in 0.06767 seconds (67.73% PHP - 32.27% MySQL) with 11 queries |
