| diyAudio Sponsor | ||
#21 |
Turns out my Fleetwoods differ slightly. The biggest difference is that one has way bigger OPTs -- and a bit of weird circuitry on the input of the power tube. The one with the smaller OPTs -- still substantial for 50EH5s -- is a Baycrest. This one has the same OPTs as Giovani's.
The amp is actually Japanese, and much more neatly constructed than the typical North American or German units. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#22 |
Here is the essentials of the circuitry... with only a requirement for 2.5V to reach full power the 12AX7 is way overkill (and may partially explain the large gridstopper). The grid leak on the power tube is one of the tone control pots.
dave
#23 |
And here is the minimalist design i'm hoping to get away with... no grid stopper, wired in triode (lower power, lower output resisitance), no cathode bypass (some degeneration, higher output resistance). If i can get away with it, then the only cap in the signal path is the last power supply cap.,,, with only a requirement for 200V i can put a nice poly there.
dave
#24 | |
Is that 6CA4 tube of any use in a power supply. I am also interested in a preamp. Can the ECL86 tubes be used for that? Cheers, Gio.
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#25 | |||
dave
#26 |
Just for fun, I decided to power up the two old consoles. A little to my suprise, they still worked! Some of the capacitors must be dead as you get clicks and pops. I did get a kick playing an mp3 player through them. The radio sounds very good!
Other than the audio tubes and iron, what is worth salvaging off of these consoles? Are the radio tubes worthwhile to hang on to? I imagine the electrolytic caps will be close to dead. Are the carbon comp. resitsors worthwhile to pull, they are mostly silver tolerance? These capacitors caught my attention .. they look like some sort of poly. Gio.
#27 | |
![]() dave
#28 |
Hi Dave,
Any thoughts on those capacitors? The outside feels like ceramic? Sorry, with only one good driver I did not bother pull the speakers. I will take pictures next time. I think I may go hunting for more consoles this weekend. I'd still like to get some more parts for a phono amp as I am not sure about an ECL86 phono amp. Do these consoles ever contain any sizeable chokes? As for the 50EH5 tubes, I'd like to try a small wattage amp which I would use for the office since I have to play music very quietly. I have been playing around with PSU Designer II...very nice, I can't wait to build a powersupply using an EZ81. Is there something similar available that would help me design an amp or preamp? Regards, Gio.
#29 | |
I don't think i've ever seen a choke in a console hifi.... organs thou are often quite rich for power supply bits. dave
#30 | |
Regards, Gio.
| Telefunken Consoles: not just for tube and iron scavenging! | pjanda1 | Tubes / Valves | 3 | 20th August 2008 10:40 PM |
| My friends in the USA - tube stores in LA | Rob11966 | Tubes / Valves | 3 | 4th August 2008 04:51 AM |
| Any tube stores in Burnaby, Vancouver, Canada? | qguy | Tubes / Valves | 2 | 12th July 2008 01:16 AM |
| tube stores in moscow | trancy | Tubes / Valves | 1 | 5th August 2005 01:14 PM |
| Thrift store find | Magnetmaz | Tubes / Valves | 37 | 13th August 2003 04:24 AM |
| Page generated in 0.14546 seconds (79.54% PHP - 20.46% MySQL) with 11 queries |
