5687 push-pull amp - diyAudio
Old 6th August 2002, 04:20 AM   #1
tiroth is offline tiroth  United States
Default 5687 push-pull amp
Ok. Now that I've had some success with a tube-input SS amp, I've decided to flip things around and try a SS-input tube amp. This would be for highs only in a biamp setup.
This looked like it could be fun, especially since I already have all the pieces.
My request for aid? I'd like a little feedback, BUT, I want to drive the input stage differentially, so there goes my easy NFB port. What are my other options for introducing feedback?
Also, any opinions on CCS replacing cathode resistor and bypass?
Old 6th August 2002, 04:27 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: 5687 push-pull amp
Bob Danielak is always coming up with cool amps -- many of them quite unusual. His Fiat has tube amplification.
Particularily a good idea on the 1st differential stage.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
OB push-pull tinitus Planars & Exotics 3 23rd April 2009 12:17 AM
6V6 Push Pull J_Hart_14 Tubes / Valves 16 4th December 2008 09:53 PM
push-pull PWM IC chimi Power Supplies 19 4th September 2008 10:32 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 01:23 AM
Copyright 1999-2017 diyAudio
