www.diytube.com Kits - diyAudio
Old 26th January 2005, 03:13 AM   #1
Coulomb is offline Coulomb  England
Coulomb's Avatar
Default www.diytube.com Kits
I am considering the dual Mono EICO partial kit from diytube.com this is thier blurb.
The design closely resembles the Eico HF-series which used a modified Mullard 5-20 circuit. The Eiclone (pronounced ‘eye-clone’) uses the 12AX7 as the voltage gain stage tube, as did the classic Eico HF-87 and HF-89. This gain stage DC-couples to a 6SN7 long-tail pair phase splitter driving a pair of push-pull EL34 tubes. The bias supply and grid resistors in the standard design are compatible with alternate power tubes such as 6550s and KT88s.
It is a PARTIAL kit meant for experienced tube hobbyists, and it includes:
two ultra-heavy duty PCBs with silkscreen on both sides - 50% thicker and with 100% more copper than your average PCB
new 'Rev B' design allows the experienced DIYer many undocumented options (eg 6SL7 sub for the 12AX7, CCS for the LTP, etc.)
robust 16-page manual containing: straight-forward instructions, detailed schematics, assembly artwork and templates - see here (~500k PDF)
parts list w/ Mouser.com part numbers and BOM support
email support provided
a growing community forum and tons of project pictures on diytube.com
Most parts can be purchased easily through Mouser, and vendors are suggested for the others (ie transformers, tubes, and tube sockets). This design is intended for all new construction using Hammond transformers: 274BX power transformer and 1650N outputs. Pictures showing completed projects are not indicative of auction contents. Design is to be oriented for a tube out construction.
Go to diytube.com for more info and pictures.
Anyone tried this kit or this topology?
Anthony
I like to stay current!
Old 26th January 2005, 08:08 AM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Would probably work fine. You might want to use 6SL7s in the front end though, would sound better. Use KT88s for max power. Dont solder sockets to the board but run wires instead to a large chrome chassis with sockets & trannies mounted on top.
I actually wish I had seen this kit before i started point-to-point wiring- would probably have halved the time to finish my amp, not to mention made it a lot neater!
So yeah probably a good idea eh.
Old 26th January 2005, 11:22 AM   #3
Coulomb's Avatar
Hello SHIFTY, Thanks for the tip on the tube selection.
Anthony
Old 27th January 2005, 12:18 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
Hi Anthony,
I am a happy owner of an HF-87a. Uses 6SN7's, 6CA7's for outputs and 12AX7A for input. The output iron is larger than normal on a real HF-87A. (larger than other amps that power rating)
Build it and be happy.
-Chris
Old 27th January 2005, 12:48 AM   #5
KBK is offline KBK  Canada
I need some tube amps..but I'm short on free time! Rotac used to have the 'passion' kits, which were kinda cool. They gave up on that. darn.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 27th January 2005, 03:17 AM   #6
Coulomb's Avatar
Well I bought a pair of these boards from Shannon of tubediy.com, now I am just waiting for thier arrival. I think I am going to try the 6SL7 input as suggested. The Output Transformer is a Hammond 1650N good for 60 watts PP, I would like to investigate one of the bigger 1650 transformers as a possible replacement.
Anthony
Old 28th January 2005, 12:39 AM   #7
anatech's Avatar
Hi Anthony,
Those xformers should do fine. If you leave extra room on the chassis you can try the other ones later.
Are you going to use EL34's or 6CA7's ?
-Chris
Old 28th January 2005, 02:12 AM   #8
Coulomb's Avatar
Originally posted by anatech
Hi Anthony,
-Chris
Well I was thinking KT88's as suggested by SHIFTY,
Anthony
Old 29th January 2005, 12:41 AM   #9
anatech's Avatar
Hi Anthony,
I was just curious. The project power has gone up a fair bit with the KT-88's. I thought you were still down in EL-34 / 6L6 power ranges.
-Chris
Old 29th January 2005, 03:22 AM   #10
Coulomb's Avatar
Hello Chris, I ended up getting the Eico boards instead of the ST35 boards. The Eico uses a 1650N output transformer which is rated at 60 Watts as opposed to the much smaller transformer of the ST35 which develops 17.5 Watts.
Am I on subject here? Is that what you were referring to Chris?
Anthony
big doubt: dynakit st35 VS diytube st35clone leitmo Tubes / Valves 5 26th February 2016 10:28 PM
Diytube ST35 rev d whitelabrat Swap Meet 8 28th May 2010 08:36 PM
ss amp kits. tom10 Solid State 0 27th July 2008 03:33 PM
USB to XLR kits? tommas Digital Source 2 4th August 2007 01:45 AM
FS DIYtube ST-35 parts kit Jed Swap Meet 2 8th January 2007 03:28 PM
Copyright ©1999-2017 diyAudio
