diyAudio Sponsor
Old 17th January 2005, 02:44 AM   #1
Lightbulb preamp gain and output transformer question
Hi, i just done my firt tube amp... A combination of 2 channel preamp driving by paralle 6v6gt power tube. But, i want more gain to produce more distortion...( never enough ). So can anybody give me some trick to do it ? here the preamp schematic i used
Also, i use a Push-pull output transformer and use it like a single ended. I just didn't hookup the CT. it's O.K. to use it like that or what can i do ?
Dan
Old 17th January 2005, 02:58 AM   #2
SY's Avatar
I'll take care of your second question: no, you can't. An SE transformer has a different geometry to prevent the core from being saturated by DC. If you capacitively couple (the so-called "parafeed"), you could use the p-p transformer, but it's not an ideal trade-off.
Short version: if you want SE, buy an SE transformer.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 18th January 2005, 08:05 PM   #3
i choose to modify my amp and transform it into a push-pull amp. i will add a 6sl7 tube for the phase inverter.
1:1 output transformer question Tyimo Solid State 31 16th January 2007 02:14 PM
Preamp question/ input gain boost 3-LockBox Class D 2 13th June 2006 04:23 AM
Output stage/preamp with gain: X-Bosoz with diff.-pair? Onvinyl Pass Labs 1 19th July 2004 09:29 AM
passive preamp with transformer output - which parts to use? krishu Parts 9 1st June 2004 05:33 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 05:36 AM
Page generated in 0.06067 seconds (79.79% PHP - 20.21% MySQL) with 11 queries
