Need info about 5G84 tube - diyAudio
Old 12th January 2005, 04:18 PM   #1
reaction's Avatar
Default Need info about 5G84 tube
Just found a pair of giant Japanese made by Toshiba 5G84 tubes with 4 pin base (3 big pins and 1 smaller in diameter) with a thick metal electrode on the top of the bulb.
The inside structure looks similar to a kind of regulator (?) - sorry I can't post pix at the moment.
Does anybody know what kind of tube is that and can provide me with more technical info? Thanks in advance.
Old 13th January 2005, 05:54 AM   #2
audiousername's Avatar
Perhaps it is a 5684?
This is a xenon filled thyratron with a large glass tubular envelope, a 4-pin base and topcap.
Datasheet here.
Jason
Old 13th January 2005, 07:00 AM   #3
reaction's Avatar
YES IT IS! Thank you audiousername!
However the 5G84 letter is clearly visible, but it can be a Japanese modification of the 5684 tube.
As far as I can see it's not suitable for audio applications for sure - what a shame for this beautiful tube
Old 13th January 2005, 08:34 AM   #4
You're most welcome.
Yes, quite a shame it's no good for audio, but it still makes a nice ornament
Jason
Schematics & Info on CAL SC-Ten Tube DAC? perfusionist Digital Source 2 16th January 2010 09:03 PM
Tube info needed Marik Tubes / Valves 0 13th February 2008 06:11 AM
Tube Info dubnikova Tubes / Valves 8 25th May 2007 11:40 PM
Need info on RCA 813 used in Tube Amp Amp_Nut Tubes / Valves 4 10th December 2006 12:45 AM
info needed on the 7c6 tube karma Tubes / Valves 2 13th August 2005 08:33 PM
Copyright 1999-2017 diyAudio
