line operated design. - diyAudio
Old 1st August 2002, 07:07 AM   #1
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Default line operated design.
I thought this one up last night.
I don't know the values for all the stuff, and I know the 50L6 isn't very "hi-fi". Now I need some low Z tubes and I can figure out some kind of completely transformerless design....
Anyhow, I know it's evil and a deathtrap. Just thought I would share it anyways
Any thoughts?
edit: forgot to put the "only one channel shown" deal in there.. wont be able to run it off the wall with only one channel..
Old 2nd August 2002, 12:06 AM   #2
Tom Bavis's Avatar
Here's a circuit by Steve Bench that avoids the "death trap" rap - http://members.aol.com/sbench/50c5.html
He uses an input transformer to isolate the circuit from the line. The grounded power cord and grounded secondary of the output transfomer make this "safe enough" that it could pass the current UL or European safety standards.
He says 3.5 Watts, but it would do more into 4 or 16 Ohms - though it might not be flat down to 20 Hz any more.
Old 2nd August 2002, 12:31 AM   #3
paulb is offline paulb  Canada
I worry about posting stuff like this without a huge warning over top of it. You'd be surprised what people will try to build.
Or post away and call it evolution in action?
Old 2nd August 2002, 01:34 AM   #4
hahaha.. should be ok if you use a polarized plug, and check to make sure the house is wired right..
I think I forgot to put in some grid leaks.. hmm..
Old 4th August 2002, 07:21 AM   #5
...and then you take it to your neighbor's house, and kill his cat.
Old 4th August 2002, 08:48 AM   #6
yeah, i suppose so.
maybe an isolation tranny would be a good idea.
(not that I leave my house anyways )
Old 4th August 2002, 08:58 AM   #7
frugal-phile(tm)
planet10's Avatar
i collect up the old CSA ground fault isolation plugs and salvage the transformer out of them. Experience says use a separate one for the heaters.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th August 2002, 09:07 AM   #8
yeah, that sounds like a decent idea.
I'm working on winding an OPT for my PSE 6V6 deal right now, and all i gotta say is.
so boring !
i really need to mechanize this if im going to finish it.. maybe put it on a dead turntable or something..
this iron might be a little on the small side too.. oh well, its just for kicks, not for hi-fi
Old 4th August 2002, 10:24 AM   #9
Circlotron's Avatar
Add a second rectifier tube to make a voltage doubler rectifier. 100 / 120 Hz ripple, nicer to the mains, and twice the plate voltage.
GP.
Old 4th August 2002, 03:58 PM   #10
frugal-phile(tm)
planet10's Avatar
In the 50C5, 50EH5 amps i am using these in, i use a SS bridge (gotta keep the filaments adding to 120V). These tubes were designed to run off not much more than 120V. I'm not sure about the 50L6 -- although i do have one of those in the parts pile.
dave
dc operated volume control steven344 Chip Amps 1 1st December 2005 12:44 PM
#47 DH pentode operated in triode alan_982002 Tubes / Valves 6 19th May 2003 10:04 AM
12V Battery operated amps r_s_dhar Analogue Source 2 10th October 2002 11:46 AM
Battery operated phono amp diyman Analogue Source 1 9th September 2002 01:52 PM
Battery Operated Supply NickC Solid State 3 24th June 2002 11:39 PM
Copyright 1999-2017 diyAudio
