Any subs for 6N1 & 6N2 twin triode valves?
I have an amp that uses two of each of these Chinese/Russian 9 pin miniature triodes and I just cannot obtain exact replacements easily. I would like to know if any more radily available tubes in North America can be subbed successfully for these. I subbed one out in the amp with a 6DJ8 and it worked but I didn't do any instrumentational testing on the amp at the time so I don't know if performance was as good, better or worse.
Thank you for any input.
thats remote cutoff triode! not pentode... this simply means that the triodes mu varies with bias... this is useful for many things. particularly AGC and compressor/limiter stuff. with a fixed bias or a small signal... the tube's mu doesn't vary. great all around preamp tube. you can make a vacuum tube volume control with it too!
jc
Oh!....I am not a tube guy:D ;) ....I just know the pentode have the remote cutoff type, not the triode. Is really what you say ?
I have the datasheet of 6N1 & 6N2.If anyone is interested in that,I would post all here.
This is the first page:cool:
hey X.G.
i'm afraid you are quite mistaken...
remote triodes are common and important for RF and AF. again, i repeat: a remote cutoff triode is simply a triode designed to vary the mu with bias. if you look at the russian 6N1P data sheet that has the plate curves, you will see if you look across the 5mA line on the plate curves that the curves flatten out as the grid bias increases. not as much as some other tubes but enough to qualify as "variable mu". actually, the 12AU7 is also quite variable mu as well and is used in one very well known and much admired studio compressor (tube tech). i don't think anyone would describe the 12AU7 as "remote cutoff" but it definitely is. in any case, a quick look at the 6BK7 data sheet will show you how close the 6N1P is... just because the tube is variable mu doesn't mean that its no good! it simply means that if you vary the bias, the gain changes. this was done to make automatic gain control (AGC) for radios and mic preamps and many other clever things.
jc
Thank you all for your assistance. I remembered that I had a 5 pack of NOS, NIB General Electric 6BK7B's and tried one today in one channel instead of the 6N1. It appears to have the same gain and sound in this circuit. It sure is a radically different tube internally though. The 6N1 has a U shaped folded plate on each side of a wide flat cathode (like a 6J6 or 6080). The 6BK7 is very tiny and looks a bit like the triode section in a 417A with a very small cilindrical cathode. I am pleased that my 6BK7 shows no sign of microphony and is otherwise dead quiet. I want to put the amp on a scope and see how the alternate tubes look.
I recall that I had used a 6DJ8 instead of the 6N2 at one time as a test and it appeared to work fine. I see that I have other alternatives. I have a good stock of NIB, NOS 6ES8's (remote cutoff triodes otherwise identical to 6DJ8) and plan to try these as well out of curiosity, and of course 6922.
BTW, the amp I'm playing with is a lovely little MingDa MC34-B. The factory supplied, performance selected 6N1's and 2's are excellent and non-microphonic but I know they won't last forever.
nanana said:
hey X.G.
jc
Thanks a lot for your kind reply and the detail explanation:hbeat:
...my more infos of the Chinese tubes;):cool: :
Basing on the history reasons,Chinese tubes almost are based on/same as the Russian tubes,and their parameters are identical in generally:
the chinese website shows that:
http://www.ds-hifi.com/dgzl/dangguan12.htm
1.6N*(6N1P,6N2P....etc) is based on 6H*( 6§¯1§±,6§¯2§±..) of Russian tube...(I type that below in simple:D : 6N*=6H*)...... IIRC,All are twin triodes
the link is for hint:D:
http://tdsl.duncanamps.com/tubesearch2.php?TSD=6N1&btnSubmit=Query
2.6J*(6J1P,6J2P...etc) is based on 6§¨*(6§¨1§±,6§¨2§±...etc)...IIRC,all are pentodes.
http://tdsl.duncanamps.com/tubesearch2.php?TSD=6J&btnSubmit=Query
3.6P*=6§±*....IIRC,they are 'power' tube:D (including pentode,beam tube ...and the type which I don't recall:cannotbe: ...etc)
http://tdsl.duncanamps.com/tubesearch2.php?TSD=6P&btnSubmit=Query
4.6C*=6C* of Russian tube....IIRC,they are single triode(I just know a bit about them,cause they are less for us:bawling: )
5.FU-*=§ÔY-* ...IIRC,they are radio tubes for transmmit
good luck
X.G.
from China (of cause!:D)
diyAudio Senior Member
Joined 2002
Good grief, people.....:rolleyes:
6N1-P
250V/5.5mA bias
mu = 35x
gm = 4500µA/V
rp = 7800
6N2-P
250V/1.8mA bias
mu = 97x
gm = 2250µA/V
rp = 43000
Both 6.3V heaters only.
So no the 6N1-P is not a 6DJ8 neither is it a 6922.
How could it be?
The 6N2-P is similar to a 6AX7 but not quite so don't go popping those in a phonostage or you'll muck up the RIAA correction to say the least.
The 6N1-P has been sold for decades as a 6DJ8, especially in the USA during the cold war.
That doesn't make it a 6DJ8 but don't get me started........
Business construction :
Electronintorg USSR governmental export agency exports to Europe.
Europe rebrands the goodies as if they were made locally and voila, import embargo from USSR to the US circumvented....
I'm innocent, I swear.:angel:
Hope this settles it,
Cheers,;)
P.S. X.G. was on the right track from the start.........
Joined 2002
I should have specified the 6N1P can sub 6DJ8, but not the other way around, because of the maximum Vp difference.
You can just as well throw that Svetlana datasheet in the dustbin, it's utterly worthless.
Also keep in mind that the heater of the 6N1-P draws 600mA.
Vp max is 300V BTW.
Cheers,;)
P.S. BTW Geek, isn't that a 6N1-P in your avatar?
