Old 11th January 2005, 01:20 AM   #1
zxx123 is offline zxx123  United States
Angry Mysterious Output Transformer....
I bought a pair of OPTs from ebay.
The guy told that he removed them
from an old german receiver which was powered by
single ended el84.
I found some problems.
1.
Unlike what I heard, it does not look like
a SE one. I see seven wires around the
transformer. Yes, it looks like not a SE, but PP type
OPT with UL tap.
Well, it seems to be little bit small for PP because
the center area was just 1.5 inches.
2.
Two are thick, but the other fives are as thin as hair.
I wonder whether these hairy wires can hold signal
clearly.
_____________________________________________
SE?, PP?, Universal? Either way, I don't know how to
handle this.
Old 11th January 2005, 02:43 PM   #2
helan is offline helan  Finland
Perhaps not a mystery
Hi zxx123
I think the transformer is for single ended use, and if equipped with 7 taps, the following construction:
Winding 1: Primary with 1 tap, like a UL-winding, letīs say tap a,
b and c;
tap a: to EL84īs anode
tap b: (nearer tap c on the winding) input +V from PSU
tap c: output for EL84 screen grid(in pentode mode)
and driver tube(s) +V voltage(s)
With other words, anode load Ra (5,2kOhm) between
tap a and b, between tap b and c you have a choke
for driver tube(s) +V including EL84īs screen grid
(see below)
Winding 2: Secondary, independent NFB winding
Winding 3: Secondary, independent loudspeaker out
A typical PS topology from the tube radio era:
Rectifier -> 50microF to GND -> to tap b, from tap c -> 1kOhm(normally 3W) resistor -> 50microF to GND -> EL84 screen grid and driver tube(s) anode resistor(s) with possible additional filtering between.
Cheers......Ole
Old 12th January 2005, 12:09 AM   #3
Default Thank, However................
Thanks, helan!
However, I need more explanation.
1. As you can see, five of wires are thin
and two of wires (dark brown) are thick. Can you agree that
the two thick wires are secondary tabs for speakerout?
It will be easier if I know secondary ones.
(Even if you are not sure, just tell me YOUR THOUGHT.
I will do full responsibility of my own for test.)
2. Now, I know three of wires are anode, ul (for screen grid),
and B+ and two of wires are +/- of speakerout.
How about the remaining two wires of them? It sounds like
they are winding 2: Secondary, independent NFB winding.
Right?
3. Do you know how I examine what are tab a, b, and c among tabs?
Is there any resistance value difference among those tabs?
4. Can I use the OPT without three (one UL & two NFBs) of those seven wires
Old 12th January 2005, 03:16 AM   #4
DUG is offline DUG  Canada
Why not inject 1Vp-p into the "speaker" lines and measure what is coming out on the "primary" (level and phase)
Doug We are all learning...we can all help
Old 12th January 2005, 03:22 AM   #5
Dave Cigna's Avatar
Have you measured the DC resistance between different terminals?
That's the first step.
Old 12th January 2005, 04:52 AM   #6
Thanks, guys!
I measure resistance value between taps
with my ohmmeter (Max 2k ohm).
1-2 513
1-3 512
2-3 48
4-5 1 (?)
6-7 17
all others are nothing.
Old 12th January 2005, 09:05 PM   #7
Dave Cigna's Avatar
Originally posted by zxx123
1-2 513
1-3 512
2-3 48
Are you sure about those?
Kirchhoff would find that interesting.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Mysterious UTC X-2806 / RCA 949426-2 Transformer snoopyma Tubes / Valves 4 21st December 2007 12:05 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Mysterious runaway output tube trombone Tubes / Valves 8 26th March 2005 08:03 PM
Copyright Đ1999-2013 diyAudio
